So which scales better AMD or NVidia
Man of Honour
21 May 2012
Dalek flagship
Just ran a few benches @4K with 1 and 4 cards @stock.
Max settings were used as it shows GPU scaling best even if playable fps are rubbish.
No overclocking was used as we are looking for scaling not playable fps.
CPUs and GPUs used
3930k @4.0ghz + 1 and 4 Titans.
4930k @4.0ghz + 1 and 4 290Xs
No 2 and 3 card runs tested as 4 card results will give a good idea what less cards are capable of. Also it is difficult for me to get to the SLI bridge on the NVidia cards.
Tomb Raider
NVidia
Single card
4 cards
Scaling = 3.94x
AMD
Single card
4 cards
Scaling = 3.83x
Sleeping Dogs
NVidia
Single card
4 cards
Scaling = 3.83x
AMD
Single card
4 cards
Scaling = 3.86x
Sniper Elite V2
NVidia
Single card
4 cards
Scaling = 3.81x
AMD
Single card
4 cards
Scaling = 3.93x
Thief
NVidia
Single card
4 cards
Scaling = 2.91x
AMD
Single card
4 cards
Scaling = 3.05x
As you can see from the games used it is very very close as to which is better and well within the margin of error to choose a winner.
Some things that could have a tiny effect on the result were -
Frame pacing was not used as I was after the scaling not the visual appearance.
The AMD cards were on a slightly more efficient CPU.
Christ those frame rates with 1 card are awful, likely be years before i consider a 4k screen.. and i guess years before a single high end gpu can handle it well enough.
Considering it's Titans against 290x's I'd say the 290x's hold their own against cards almost double the cost!
I get very acceptable frame rates in Tomb Raider on medium-high settings on a single 780 Ti. I have Tress FX and AA off.
It's a pretty good showing all around. It was not so long ago 4 way was showing negative scaling in a lot of games. These days in the big titles it's almost expected to work well where as years ago it was a bonus.
Almost double the cost.
However also much older, with much more OCing headroom, more memory, better coolers and full double precision performance.
Nice results Kaap and good scaling. 4K sure is for multi card users and will be for a long while. 4K does look decent with lowered settings still but who wants to do that? :p
yep and the reason why the prices will have to crash down to 200-300 before people start buying in .
1 top card and them fps are a joke :p
Have you ever done scaling tests at lower resolutions with 2 way sli/crossfire? Whilst I appreciate you doing all these tests, they lack a certain amount of applicability to most people.
Minimums are overrated without a graph. That could have been a one off and the Nvidia cards could have been lower 90% of the time. From what i have seen on HardOcp the 290x maintains a decent frame rate with fewer dips. The game play experience is what matters and i doubt it's much different on either system. Kaap seems pretty happy with both.
