AMD Readies FX-8370 For AM3+ and A4-7300, Athlon X4 860K / 840, Athlon X2 450 CPU's
Take this with a pinch of salt for the time being, but interesting as it appears these new chips are indeed a new revision.
The Stilt @ xtremesystems.org | 2nd September 2014 said:
FX-8370E = 3.3GHz (Base), 3.6GHz (Boost, 4CUs active), 4.3GHz (Boost, 2CUs active, 2CUs gated)
FX-8370 = 4.0GHz (Base), 4.1GHz (Boost, 4CUs active), 4.3GHz (Boost, 2CUs active, 2CUs gated)
So it is finally the second of September...
So far I have posted a picture of a crown (which once belonged king George XII of Georgia) and hashtags #kg & #Alphabet...
#kg which stands for Kilogram
#Alphabet... "Kilo" stands for "K" in the phonetic alphabet
So what is this all about?
Everything below is highly unofficial of course as is everything else I write here.
Piledriver module based Vishera die has been mass-produced in two different die revisions since the prototyping phase.
While all of the revisions have the same major die version (OR-C0), the minor revision has changed.
Initially the first mass-produced die revision was "India" (OR-C0i, prototype and ES only), the second revision was and still is "Juliett" (OR-C0j, retail) and now finally...
The "Kilo" revision (OR-C0k) a.k.a "King Vishera" a.k.a "Vishera Type-K" has arrived.
The "King Vishera" is initially only available in the new models, FX-8370E & FX-8370.
This is most likely the case with FX-8320E also, however I have not been able to test one of them personally.
The new version is likely to be phased-in at least in the other high-end models such as FX-9590 and at some point in all of the remaining models also.
The alledged metal tapeout of the new revision (alledgedly) occured in the beginning of July. So the only way to get a newer revision part is to get one of the new models, atleast in the beginning.
The differences?
- On average 18% less leakage*1 (0-38%) for FX-8370
- On average 53% less leakage*1 (14-106%) for FX-8370E
- Up to 300MHz higher overclocking margin *12
- 100mV less voltage required for the same clocks on average *1
*1 - Compared to an average FX-8320 or FX-8350 CPU
*2 - When not restricted by the cooling or the motherboard (VRM)
The E-version is the best choice for air or water cooling thanks to the ultra low leakage characteristics.
The non E-version does the same clocks however it might require use of a higher end motherboard (with better VRM) and high-performance cooling.
The non E-version has significantly better overclockability under sub-zero temperatures (phase, LN2) since the leakage levels of the E-version are too low for the purpose.
Having an ultra low leakage characteristics is great under normal conditions however under sub-zero temperatures the voltage requirements become a issue.
Basically the low leakage part exhaust the usable range of supply voltage prior reaching it's maximum frequency.
Based on my own tests, I would estimate that >95% of FX-8370 & FX-8370E parts will reach 4.8GHz frequency in 24/7 without a custom watercooling or a ultra high-end motherboard being a requirement.
As long as the temperature (see below) stays =<65 degree C or 149 degree F and the motherboard has even remotely a sufficient VRM you'll be fine.
On a high-end motherboard and a custom watercooling 5.0G - 5.2GHz+ should be doable in 24/7 use with a good specimen.
These chips still draws a vast amount of power when overclocked so the final overclocking potential is basically just the matter of cooling.
The maximum recommended temperature during the worst case stress is 65?C tCase.
Officially the maximum tCase temperature for the various FX models is specified to:
Infra A - FR (125W TDP) - 61.1 degree C
Infra B - WM (95W TDP) - 70.5 degree C
Infra C - OL (65W TDP) - 70.3 degree C
Infra D - HO (45W TDP) - 69.1 degree C
Infra E - SJ (25W TDP) - 70.0 degree C
Infra F - FH (220W TDP) - 57.0 degree C
The tCase temperature must not be mixed with the tCTL control value sometimes dubbed as the "package temperature".
The tCase temperature is also calculated and it represents the simulated case temperature, measured from the very center of the heatspreader (see the illustration).
Neither tCase or tCTL is the actual die temperature. The actual die temperature information is not directly available on these processors. The actual die temperature is significantly higher
than the tCase or the tCTL control value indicates.
The maximum tCTL control value on all of the FX-series processors is 70 units.
When that value is reached the processor HTC logic engages and starts to reduce the power consumption and dissipation by throttling.
Some of the motherboard manufacturers (such as ASUS) alter the limit manually to reduce the chance for throttling.
So when you are talking about the temperature always use the tCase temperature instead of the tCTL control value.
Here is the examples of the wrong and right values in various monitoring softwares.
Red = Wrong (tCTL)
Green = Right (tCase)
The AOD picture also explains the value dubbed as "Thermal Margin".
Also here is a reminder why Prime95 should not be used as a reference for stability when overclocked. It results significantly higher power draw and emitted thermal than any of the most stressful real world applications.If you still find it absolutely necessary to use Prime95 for stability testing please do it this way:
Run it on only two compute units at once (set the thread count to 4 and affinity accordingly) and decrease the cooling to simulate higher power dissipation.
Only the relative Stock or OC results are comparable.
Source
Why can't they just have it read the Die temperature? it would save a lot of confusion.
Anyway, i want to see the FX-8370E and FX-8370 tested.
So yeah, if AMD could bring out something actually new in their CPU line that'd be great...
I guess it's unlikely they'll bring out an '8' core Steamroller, but maybe '8' core (or more?) 20nm Carrizo (Excavator core)?
'8'+ Core Excavator would likely be quite nice in today's CPU market. I mean if they can do '8' Piledriver cores for £130 on 32nm, they should be able to offer '12' Excavators for a similar price at 20nm, and that would be a very tempting package for multi-threaded stuff at least (judging on Steamroller's '4' core performance).
Poor old AMD, really are lost.
And these 6pack deals, who has six friends that are wanting to upgrade their computer at the same time, let alone to AMD.
The 6 Pack deals are for small time system builders, they exist and it is useful to them :)
Anyway. Stulid, any plans of testing one of these? i want to see how true the binning and revision of these effecting the power consumption and overclocking vs the older FX-83## revisions is.
No more AMD for me (unless hell freezes over/pigs fly/aliens are confirmed to exist/Roswell was real and AMD do something stunning and release a competitive CPU or something exciting with APU's) I have moved onwards and upwards to X99
Yeah i'm looking at going Intel myself now.... Well, not right now... but thats not what i'm asking :p
Your Staff and a professional reviewer, i'm asking if you can go grab one and make a comparison review? :)
Yeah i'm looking at going Intel myself now.... but thats not what i'm asking :p
I just don't want to. Sad I know but i'm getting bored by all these insignificant releases that drip feed a few extra % improvements or try and fill a price gap between two products.
I do have an AM3 board and FX8320 here and could possibly get one of these new CPU's, but really cant even be bothered to type up an email asking as I know it will bore the crap out of me testing it.
I can not see why AMD just cannot continue to produce and sell the FX8320/8350 at the price (or lower to stimulate demand) that they have been doing.
Then there is AM3 socket in itself, is this one last pointless hoorah before something new comes along to replace it? I think so.
I wish the good days of radeon 9700Pro or 8800GTX or Conroe CPU's would return which did smash the previous gen properly and the competitor products.
I just don't want to. Sad i know but i'm getting bored by all these insignificant releases that drip feed a few extra % improvements or try and fill a price gap between two products.
I cant see why AMD just cannot continue to produce and sell the FX8320/8350 at the price (or lower to stimulate demand) tat they have been doing.
Then there is AM3 socket in itself, is this one last pointless hoorah before something new comes along to replace it? i think so.
Fair enough Stulid :)
I can't see myself with FX-8350'ish performance and overclocked power consumption that makes a very strong Motherboard like my Asus Sabertooth sweat for much longer.
I like the CPU, but the power consumption is causing problems, i think its causing voltage drooping on all the rails resulting in random system freeze-ups when loaded.
Unless the Motherboard / PSU / RAM is on its way out, i don't know, its hard to pin down, i just can't seem to find a happy place for it, its just so random...
Thats why i want to know if these are any more efficient, its not going to put me much out of pocket to swap my FX-8350 for one of these.
I think unless AMD do something 'real' by the time the 390 / GTX 980 GPU's get here i will probably end up rebuilding with an i7.
Thanks anyway :)
There is a review - http://www.anandtech.com/show/8427/amd-fx-8370e-cpu-review-vishera-95w/2
8370E which is £145, but unfortunately it gets rek't by the 8350 which is £125.
What are they thinking.
(no one cares about power consumption when dealing with this sort of platform either? if they did they would go intel i5)
To top it off they positioned its product name higher than the 8350 too, so someone less "clued" up will be in a shop looking at the two CPU boxes and think the higher number = better performance.
It will be, 3.3Ghz vs 4Ghz...
This is what i was looking for.
~100 Watts less, am i seeing that right?
You do realise these are probably dies from their Warsaw Opterons??
You do realize no-one cares where the dies come from and are more concerned about bang per buck which this does not have.
They introduced a new stepping for Warsaw Opterons this year and these are those new stepping CPUs now sold at retail.
So I answered your question and you started ranting at me.
Take your attitude and complain to Warsam71 but don't stick it at me.
I did not ask a question for you to answer, I don't actually care at all about the DIE or what city it is named after or how big it is and how many transistors it contains. I did not ask anything about the DIE, but I did say what are they thinking releasing a product which is slower and costs more than the current CPU's.
All that ultimately matters is price/performance. Which this is a step backwards.
Quick question what is the difference with these new AMD processors to me they just look overclocked and same architecture ad the 8320
http://i1349.photobucket.com/albums/p750/edwarhys/Mobile%20Uploads/Screenshot_2014-09-02-18-51-08_zps4bgstlnl.png[/IMG[/URL][/QUOTE]
The ones with an "E" use less power/lower TDP.
If you have a good AM3 board it will support a 125W version anyway so the FX8320/8350 are a more sensible purchase.
[quote="CAT-THE-FIFTH, post: 26840366"]
You asked a question why they released it,and now you ****** out of it when I answered it.
[/QUOTE]
I did not try and get out of anything! where?
I said and I quote,
[quote="stulid, post: 26840263"]There is a review - [url]http://www.anandtech.com/show/8427/amd-fx-8370e-cpu-review-vishera-95w/2[/url]
[B]8370E which is £145, but unfortunately it gets rek't by the 8350 which is £125.
What are they thinking.[/B]
To top it off they positioned its product name higher than the 8350 too, so someone less "clued" up will be in a shop looking at the two CPU boxes and think the higher number = better performance.[/QUOTE]
That is all I asked.
"price/performance"
Nothing about DIES or Warsaw etc which you pointlessly chimed in with;)
[quote="CAT-THE-FIFTH, post: 26840289"]You do realise these are probably dies from their Warsaw Opterons??[/QUOTE]
[quote="stulid, post: 26840299"]You do realize no-one cares where the dies come from and a[B]re more concerned about bang per buck which this does not have.[/B][/QUOTE]
