- 18 Oct 2012
positive
as an example it looks like this:
N 52° 45.495 E 006° 53.843 as do all coordinates in Geocaching
That might not be right.
You need a 3 digit number (xxx) and you have 3 images, so it's likely that each image refers to a single digit.
What FoxEye is saying is that each image might not be a single digit.
For example, if the 3 images for the X numbers are 84, 84 and 27, add them together and you'll get a 3 digit number.
Ok pretty sure its not going to be shaded fractions. if you rotate all the circles to the same direction they look equal. Am I being blind?![]()
I will add to all this that I am fairly certain that the first digit in the X group is a 7, not definate but fairly certain.
I don't think it is going to anything that accurate, these puzzles are designed to be solved in the field.
If you needed anything to measure angles in order to solve it then the cache attributes would state special tools required and they don't
i see you missed my edit, if your saying on the general area the first x is a 7, is there an equivalent for y?
i dont know how devious the person who set the challenge is, but i'd assume it would all be the same direction for each shaded section otherwise the challenge would, as you pointed out, be simply too hard.
using the 3rd technique, could say for example:
x=005 y=802
thats roughly ofc, i couldnt be bothered to draw them out and the minds eye gets confised easily lol
I really enjoy Geocaching
No idea how to figure out the puzzle. I'd Email the owner for a clue or scan through the logged finds looking for a hint.
best guess is a 5 or 6
The big problem I have is that Y1 is half-way between 8 and 9 (or 3 and 4). That's pretty darn terrible if you're supposed to solve in the field and each is supposed to be 0-9.
Ok, i got it.
Clues:
1- each image is an individual digit.
2- the first x is not a 7
blows a hole in another theory, can you at least confirm the decimal clockface is correct?
