Corsair AX1200i random buzz
Permabanned
4 Sep 2011
Durham
Hey,
So as the title says my 1 year old corsair psu has made some strange sounds over the last couple of days. Its had a slight buzzing from day one but its very slight and constant and can only be heard when right next to it but once today and twice yesterday a 2 second louder,short buzz has happened which was quite a bit louder. I cant replicate it nor is the system unstable but it does worry me non the less. Anyone have any ideas and is this reason to be concerned?
What are you seeing in the link software ? have you got logging running so you can take a look at the outputs at the time of the noise ?
Cheers dude. Well I cant run the link software as a wire came loose from the little adapter type part of the link cable. TBH at this point Im looking at a new case for xmas so when I take it apart to rebuild I might hot glue the PSU to quieten it anyways.
Lets say the PSU is on its way out (please god no) and it does fail on me would it take anything else with it? Im assuming the fact the PSU was £240 means it has some kind of protection?
Thanks for the reply :)
