----- #AMD FRIDAY: SAPPHIRE 295 X2 @ £699.99 PLUS OTHER INSANE DEALS!! -----
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK this is one very special AMD Friday, this deal is truly insane and IS LIMITED to 100 units, so no moaning for the snoozers who miss out!
The 295 X2 price will remain at £699.99 until they are sold out, all other prices will go back up on Monday!
SNOOZE, YOU LOOSE!!
Remember when you buy a 280 or above from OcUK, you also get GOLD Never Settle Space award:-
NS_Space.jpg~original
THE DEALS!
Sapphire AMD Radeon R9 295 X2 8192MB GDDR5 PCI-Express Graphics Card @ £699.99 inc VAT
No matter what the game or the resolution you can now select the maximum settings even at 4k resolution and enjoy fluid ultimate smooth framerates in latest games such as Titanfall, Diablo 3, Watchdogs and even potential upcoming games such as GTA V and Half Life 3 should they surface.
Featuring a pair of 290X Hawaii GPU's fused onto a single PCB with an advanced PLX chip along with only requiring 2x 8-Pin power connectors.
The other major feature of the 295 X2 is its cooling solution which truly does keep the cards temperatures around 60c even after gaming for hours and it also manages to do this in more or less silence with zero throttling of the cores themselves. Making it one of the smoothest, quietest and easily most powerful graphics card on the market today. If you really crave the most powerful and have or are considering a 4k monitor for gaming then the 295 X2 is the card for you.
If your demands are truly the most powerful experience possible then these cards work great in Crossfire (4 GPU's) and you will be able to smash benchmarks to pieces and have no slow downs in games.
Specification:-
- GPU: 2x Hawaii XT
- Hybrid Liquid Cooling
- Litecoin Hash Rate: 1600-2000
- Stream Processors: 5632
- ROPS: 128
- Core Speed: 1018MHz
- Memory Speed: 5000Mhz
- Memory interface: 1024-Bit (2x 512-Bit)
- Memory capacity: 8192MB GDDR5
- PCI-Express X16 lane required
- 850W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Case capable of fitting such a long card and support for a 120mm radiator
- Dimensions: Card is 307x111x65mm and Cooler is 153x120x63mm
- Power Connectors: 2x 8-pin
- Display Outputs: 1x Dual Link DVI, 4x Mini-DisplayPort
- Warranty: 2yr
Was [£1039.99] Inc. VAT
Only £699.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290X Vapor-X OC 4096MB GDDR5 PCI-Express Graphics Card (11226-10-40G) @ £389.99 inc VAT
The SAPPHIRE R9 290X Vapor-X OC features several of the company’s industry-leading technologies and a factory overclock to deliver best in class performance with very low noise.
Based on the award-winning Graphics Core Next (GCN) architecture from AMD with 2816 Stream Processors, the SAPPHIRE R9 290X Vapor-X is an Overclocked edition which boasts 4GB of the latest GDDR5 memory running at 1410 MHz (5.64GB/s effective) and high speed engine clocks of 1080MHz.
SAPPHIRE’s innovative Vapor-X cooling technology allows products to run not only cooler but also much quieter. A Vapor-X product means a virtually silent gaming experience and more headroom to explore performance tweaking!
Choke is an important component of the graphics card. By working with the component engineer, Sapphire’s patent pending choke is 10% cooler and offers 25% more power efficiency than a normal choke. The graphics card will be more reliable and save energy.
Improved reliability and better overclocking are possible by using only high-polymer, aluminum capacitors which posses far superior characteristics than regular aluminum capacitor for a longer product life. When operational temperatures drop by 20°C, the product life span is extended by a factor of ten, when the operational temperature increases by 20°C, the product life span only decreases by 10%.
Along the edge of the card the PCB is extended and one of the copper layers left exposed. An additional heatsink mounted directly to this copper layer allows heat absorbed into the PCB from the GPU and other components to be transferred to the heatsink and cooled by the airflow. This feature alone can reduce core temperature by 2 degree C.
Specification:-
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1080MHz >
- Memory Speed: 5640Mhz
- Memory interface: 512-Bit
- Memory capacity: 4096MB GDDR5
- 600W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Was [£419.99] Inc. VAT
Only £389.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290 Vapor-X OC 4096MB GDDR5 PCI-Express Graphics Card (11227-04-40G) @ £299.99 inc VAT
Sapphires 290 Vapor-X is the fastest 290 on the market with a core clock of 1050MHz but even more impressive is the 5600MHz memory clock and with 4GB of RAM making this card perfect for 4K resolution and latest games such as Titanfall, Diablo 3 etc.
The Vapor-X cooler is simply the best cooler available full stop on any 290 card, it operates in near silence but has incredibly powerful cooling ability making this a great card for both gamers and overclockers.
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Litecoin Hash Rate: 800-950 <br />
- Stream Processors: 2560
- Core Speed: 1030MHz
- Memory Speed: 5600Mhz
- Power Connectors: 2x 8-pin required
- Warranty: 2yr
- Kitguru Review: http://www.kitguru.net/components/g...280x-vapor-x-oc-and-r9-290-vapor-x-oc-review/
Was [£329.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290 Tri-X OC 4096MB GDDR5 PCI-Express Graphics Card (11227-00-40G) @ £259.99 inc VAT
AMD Radeon R9 290 is a new graphics card powered by the latest AMD Radeon™ R9 290 graphics-processing unit (GPU). 4GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290 also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290
- GPU: Hawaii Pro
- Core Speed: 1000MHz
- Memory Speed: 5200Mhz
- Warranty: 2yr
Was [£299.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
Aqua Computer kryographics Vesuvius for 295X2 Black Edition @ £131.99 inc VAT
This cooler combines the features of a graphics chip cooler and RAM-coolers in an elegant and very flat watercooler. Additionally the voltage regulators are also cooled effectively.
The kryographics for R9 295X2 water block offers outstanding cooling performance and a low flow resistance. All mounting threads are equipped with spacers for easy installation and to prevent twisting the graphics card. The areas contacting the GPU and RAM modules are polished for excellent heat transfer. For the voltage regulators, a thermal pad with high thermal conductivity is included.
The kryoconnect water block series features a delrin connection terminal that has a significantly reduced flow resistance compared to the previous aquagraFX series. The terminal is fastened to the water block by three screws and has G1/4 inlet and outlet ports on each side for flexible installation. Two sealing screws are supplied to seal the unused connection threads. The terminal can be replaced with kryoconnect kits for Crossfire configurations .
Notes: The cooler is indeed ready mounted, but this is for illustration only. The graphics card is not included. Technical details:
Specifications:-
- Material: Copper (base),Black acrylic (cover), stainless steel (top frame), Delrin (connection terminal)
- Thread: 4x G1 / 4 inch
- Compatibility AMD Radeon R9 295X2 (Hawaii XT, 8192 MB, reference design)
Was [£139.99] Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
Aqua Computer Kryographics Vesuvius 295 X2 Acrylic Edition @ £119.99 inc VAT
Specifications:-
- Material: Copper (base), acrylic (cover), stainless steel (top frame), Delrin (connection terminal)
Was [£134.99] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 850W Fully Modular "80 Plus Gold" Power Supply - Black @ £97.99 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:-
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Gold Certified, 90.43% 92.03% 90.27% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Speciication:-
- Type: ATX
- Maximum Power: 850W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage Full Ranage - 100V~240V
- Input Frequency Range 50 ± 3 Hz / 60 ± 3 Hz
- Output +3.3V@24A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Protection OVP?OCP?OPP?SCP?UVP
- Dimension 200mm(L) x 150mm(W) x 86mm(H)
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Was [£109.99] Inc. VAT
Only £97.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 1300W Fully Modular "80 Plus Gold" Power Supply - Black @ £137.99 inc VAT
Features:-
- 80 PLUS ® Gold Certified, 91.09% 91.75% 89.25% Efficiency At 20% 50% 100% Rated Load
Specification:-
- Type: ATX
- Maximum Power: 1300W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable Yes 100% modular cable design
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
- Review: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=367
Was [£149.99] Inc. VAT
Only £137.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - Black @ £139.99 inc VAT
Leadex Platinum series PSU are 80+ Platinum certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Features
- 80 PLUS ® Platinum Certified, 91.12% 92.53% 91.11% Efficiency At 20% 50% 100% Rated Load
- Product Review: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=340
Specification:-
- Type ATX
- Maximum Power 1000W
- Fans 1 x 14cm
- PFC Active
- +12V Rails 1
- Output +3.3V@20A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- 1x 8-Pin EPS12V
- 6x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £139.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - White @ £139.99 inc VAT
Features
Specification:-
- Type ATX
- Fans 1 x 14cm
- PFC Active
- +12V Rails 1
- 1x 8-Pin EPS12V
- 6x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - Black @ £161.99 inc VAT
Features:
- 80 PLUS ® Platinum Certified, 91.07% 92.44% 90.47% Efficiency At 20% 50% 100% Rated Load
Specification:-
- Type: ATX
- Maximum Power: 1200W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Was [£179.99] Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - White @ £161.99 inc VAT
Features:
Specification:
- Type: ATX
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
Corsair AX1500i Digital ATX 80 Plus Titanium Modular Power Supply (CP-9020057-UK) @ £299.99 inc VAT
AX1500i is the best enthusiast PC power supply you can own. It provides 1500 Watts of continuous power – even on 115V 15 Amp circuits – and 80 PLUS Titanium certified efficiency of over 94%. Zero RPM Fan mode ensures silent operation at low and medium loads, and the fully modular, low profile cable set makes for easy installation and great-looking builds. Corsair Link integration lets you monitor power usage and efficiency and customize performance, directly from your Windows desktop. The AX1500i lets you have it all, and it’s the power supply you want for your ultra-high performance PC.
Features:-
- The best enthusiast PC power supply you can own - The AX1500i is our flagship of power supplies, designed for use in truly remarkable PCs. Built with DSP control for amazing efficiency without compromising electrical performance.
- 80 PLUS Titanium certified efficiency - 80 PLUS Titanium certification guarantees 94% efficiency and silent operation at typical loads.
- Flat black, Low-Profile Modular Cables - You can remove unneeded cables and leave them in the box for fast, easy, and great-looking builds.
- 1500 watts of reliable, continuous power delivery - The AX1500i power ratings are continuous, not peak, for superior protection for your valuable PC. Corsair uses high-quality internal components like 105°c rated Japanese capacitors and is guaranteed to deliver clean, stable, continuous power even at a server grade 50°c ambient temperature.
Specification:-
- Digital Signal Processor (DSP) for delivering extremely clean, efficient power with real-time adjustments.
- Corsair Link. Integration for monitoring and adjustment of performance, noise, and OCP settings.
- 80 PLUSR Titanium Efficiency, delivering 94% energy efficiency at real world load conditions.
- ZeroRPM mode for fanless operation at low loads and outstanding noise reduction.
- 140mm thermally controlled fluid dynamic bearing fan spins up as needed.
- Fully Modular low profile cables for easy installation, less clutter, and helps maximize airflow through your computer¡¦s chassis.
- Engineered to meet maximum power output at a server-grade 50C temperature rating.
- Self-test switch to determine PSU functionality even before installation.
- The latest ATX12V v2.4 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2, 2.31 and ATX12V 2.01 systems.
- 4th generation IntelR Core. processor Ready (Intel Haswell and Z87 motherboards).
- Over-voltage protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components.
- Safety and Agency Approvals: FCC, ICES, CE, UL / CUL, CSA, C-Tick/RCM, TUV, CB, CU, KC Mark, RoHS, WEEE, RoHS (China), REACH
- +3.3V 30A 180W +5V 30A +12V 125 A 1500W
ORDER NOW
Samsung U28D590 28" 4K 60Hz 1ms Gaming Widescreen LED Monitor - Black **OcUK Exclusive** @ £429.95 inc VAT
OcUK will be the first in the UK to get official UK version of this monitor by upto nearly a month. We are expecting our delivery the last week of May. None of our competitors will get stock until mid-end of June as we have an exclusive arrangement with Samsung. This monitor is one of the best 4k displays available and OcUK will have it before any competitor by upto at least two weeks. Pre-order with confidence from ourselves on this stunning Samsung U28D590 28" 4k 60Hz 1ms Gaming Widescreen LED Monitor.
Samsung U28D590 the Main feature of novelty is the resolution 4K (3840×2160), exceeding Full HD (1920×1080) four times. Natural color reproduction with soft color transitions is achieved, in particular, by playlist 1 billion colors. Response time is 1 MS, which perfectly fit to play the game content. Also amongst the peculiarities of the availability of an updated Picture-in-Picture (PIP 2.0). With its help it is possible to reproduce a picture of a small window in the original resolution up to Full HD (1920×1080 pixels) as the main picture is reproduced in UHD. In addition, when playing content small-resolution, innovative function UHD upscale will improve the clarity and quality of the image to the maximum possible resolution of 4K (3840×2160).
The novelty provides connectivity, audio-video devices: include 2 HDMI port and one interface connector Display Port. It is worth noting that the monitor can be connected at once two PC and play back content from both devices without any loss of quality, resolution images with each PC will 1920×2160. This monitor can be easily connected Xbox or PlayStation 4 via the HDMI.
Specification:
- Size with stand (W x H x D ) : 660.9x486.3x169.4 (mm)
- Without stand (W x H x D ): 660.9x410.0x64.7 (mm)
- Packaging (W x H x D ): 794x452x109 (mm)
- Display Screen Size: 28" (70.8cm)
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 1ms (GTG)
- Color Support : 1B
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz)
- USB Hub: NO
- Speakers: NO
- Warranty: 2yr
Was [£455.99] Inc. VAT
Only £429.95 inc VAT.
ORDER NOW
LG Flatron 34UM95-P 34" WideScreen Super-Wide LED Monitor @ £769.99 inc VAT
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
The 3440X1440 UltraWide QHD display offers amazingly sharp picture quality. Its pixel area is about 1.8 times larger than an UltraWide Full HD 21:9 monitor, and about 2.4 times larger than a Full HD 16:9 monitor. It provides an efficient environment in using Microsoft Office programs showing 47 columns and 63 rows in excel.
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
Multitasking doesn't have to mean shuffling back and forth between windows*. With a single click, the 4-Screen Split feature divides the screen into as many as four customizable segments, two-by-two. Now you can see four different windows at the same time.
The Dual Linkup feature allows two compatible portable devices--such as a computer, camera, phone, or Blu-ray player--to be connected to the monitor, and both can be viewed on the same screen simultaneously.
This monitor's Thunderbolt input/output port allows you to connect up to six compatible devices, moving data between them with incredible speed. The two channels of 10-gigabits-per-second throughput in both directions are up to 20X faster than USB 2.0. Thunderbolt is an exciting innovation for both expansion and premium video display.
The DisplayPort digital video interface is used to connect a high-performance video source to a high-resolution monitor. Thanks to its sophisticated design, a DisplayPort cable can also be used to carry audio, USB signals and other data as well.
LG’s LED backlighting delivers exceptional brightness and amazing image clarity. You'll see richer colors and deeper blacks too, and LEDs offer greater energy efficiency compared to conventional LCD monitors.
IPS (In-Plane Switching) technology enhances thA dynamic contrast ratio of 5,000,000:1 is your assurance of strong video performance, with deep blacks, bright whites and pleasing colors.e performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle.
Looking for the ultimate in fine-tuning for your LG monitor? This model is designed to work with compatible calibration devices* that take specific readings and guide you through precise adjustments of color, brightness and more.
Specification:-
- Screen Size Class (diagonal): 34"
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 320 cd/m2
- Contrast Ratio(Original): 1000:1
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Warranty: 2yr
Was [£839.99] Inc. VAT
Only £769.99 inc VAT.
ORDER NOW
Now for those who want the King of graphics and a very limited item to 500pc world-wide, I present you Ares III:-
Asus ROG Ares III AMD Radeon Dual Core R9 290X 8192MB GDDR4 PCI-Express Graphics Card - LIMITED EDITION @ £1,399.99 inc VAT
Continuing on the success of its popular ROG ARES/MARS series graphics cards, ASUS ROG today presents the fastest and most powerful graphics card currently available in the form of the limited edition ARES III. Factory overclocked Dual R9 290X GPUs running @1030MHz and 8GB GDDR5 running @ 5000MHz makes ASUS ROG ARESIII-8GD5 the Performance King by 15% faster than GTX Titan Z.
The ROG Ares III showcases exquisite craftsmanship and this can be seen in its sleek custom-designed EK water block and hand-carved details. It delivers a 25%-cooler performance than reference R9 295X. ARES III employs exclusive ASUS DIGI+ VRM and 16-phase Super Alloy Power technologies for greater stability and product longevity. The bundled ROG Edition GPU Tweak utility gives customers direct access to graphics card overclocking and tuning, tapping its power via a user-friendly interface.
Just 500 Ares III units will be manufactured, and each will be numbered individually, reflecting its collectible status.
Features:-
- Dual R9 290X factory-overclocked to 1030MHz - delivering a 15% faster performance than GTX Titan Z
- Made for water-cooled rig featuring custom-designed EK water block – running at 25% cooler than reference R9 295X2
- DIGI+ VRM with black metallic capacitors and 16-phase Super Alloy Power: 30%-less power noise and 5X-greater durability
- GPU Tweak: Modify clock speeds, voltages, fan performance and more, all via an intuitive interface
- Full Specification: http://www.asus.com/Graphics_Cards/ROG_ARESIII8GD5/
Specification:-
- GPU: 2x Hawaii XT
- Ares III Cooling (Requires waterloop kit)
- ROPS: 128
- 1000W or greater PSU required with genuine 8-Pin PCI-E cables such as Silverstone 1500W
- Power Connectors: 3x 8-pin
- Display Outputs: 2x Dual Link DVI, 1x DisplayPort, 1x HDMI
- Dimensions: 144mm x 300mm x 21mm
- Warranty: 3yr
Only £1,399.99 inc VAT.
ORDER NOW
So, just north of 800 including block.
Wouldn't be able to sell two 290s and blocks for as much as 250. So would be anywhere from 300 quid and up for me to go 295.
Will stick with third 290 pcs+.
Nice deal though. More in line with where it should be priced in reality.
Well it works out cheaper than the USA $999 price, so no point in anyone importing one now. :)
wow these are some great deals... Ares III QQ
wow i won the price is right in the previous thread :D , 699£, and 799£ with PSu :D
Omg! I want one so bad now! :( Funds are a bit low though, Fiancé and house meh..!
Edit: Would a 295x even work with a 2500k? as it is pci 2.0, and if it did work would it be a bottleneck? it doesn't bottleneck my 7950 crossfire though because im clocked @ 4.5 - 5ghz depending on how sunny it is outside :p
If I hadn't already spent near a grand this week at OcUK upgrading to X99, I would probably be getting the Samsung monitor. Bah!
Great deals though!
It's £610 from USA + about £20 for shipping. If someone has a relative or friend they can have it shipped to them via tracked and sent over as a gift declared < £38 value.
Not sure whether I should do this and save £70 (for which I need to buy a mechanical keyboard) or get this. If it was £650 it would be a no brainer to buy from OCUK.
I want to return my few day old 780 ti as it's under-performing at high resolutions and get this instead.
You have to pay VAT on it too, that'd bring it over £700 easily.
So the R9 3xx series must be around the corner? Anyway they are brilliant prices, don't think anywhere can beat most of those atm. If I hadn't already got a R9 290 with the crappy Gelid Icy Vision stopping overclocks because of VRM's and triple slot I would get a tri-x to crossfire with it.
it'll be ok, i had my i5 2500 with the 7990
yea it looks great until you stop and think, ``do i really need it, what about next years dual card because i'll deffo want that too``
``that'll be 3 dual cards in a year`` :eek:.....then the penny suddenly drops, seduction time is over ``;)
but i still need to buy something, so i'll buy another pc...probably a work bench :eek:
