AMD Piledriver FX-8 Eight Core 9590 Black Edition 4.70GHz (5.00GHz Turbo) (Socket AM3+) Processor - OEM @ £155.99 inc VAT
Unmatched multitasking and pure core performance with a new architecture. AMD FX Processors unlock maximum, unrestrained processing performance for extreme responsiveness you can see and feel. Experience unmatched multitasking and pure core performance with the industry's first 32nm 8-core desktop processor. Get the speed you crave with AMD Turbo CORE Technology to push your core frequencies to the limit when you need it most. Go beyond the limits of maximum speed. But the best part of all? You'll get all this impressive performance at an unbelievable price. You'll be asking yourself "what competition?" in no time.
Features:-
- The industry's only 8-core desktop processor
- Overclock with easy to use AMD Overdrive™ and AMD Catalyst Control Center™ software suites
- Supreme power available from virtually every core
- Aggressive performance for mega-tasking and intensive applications like video editing and 3D modelling
- The industry's first and only native 8-core desktop processor for unmatched multitasking and pure core performance
- New 32 nm die shrink designed to reduce leakage for improved efficiency, increased clock rate headroom and better thermals
- Can deliver more cores and more performance without raising the power requirements
- Unlocked processors allow the maximum tuneable performance
- AMD Turbo CORE Technology dynamically adjusts performance to give you the best experience, no matter what you are doing
- Get superior performance at a competitive price with unlocked technology
Specification:-
- Multiplier Unlocked
- Eight Core Technology
- 4.70GHz Clock Speed
- 5.00GHz Turbo Clock Speed
- 5.2 GT/s System Bus
- AM3+ Socket
- 8MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 220W
- Voltage: 1.4125v - 1.6500v
- 32nm technology
- Support upto 2400MHz DDR3
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan NOT INCLUDED: We recommend Alpenfohn K2 Mount Doom or watercooling
Only £155.99 inc VAT.
ORDER NOW
Corsair K70 Gunmetal Cherry MX Blue Mechanical Gaming Keyboard (CH-9000058-UK) @ £79.99 inc VAT
The Corsair K70 is a fully mechanical, backlit keyboard that’s designed for performance gaming. The built-in Cherry MX Blue switches deliver tactile feedback with an audible click. Every key is individually lit for brilliant backlighting and easy customizability to highlight important functions. The brushed aluminum structure provides rugged durability and a professional-grade finish. Replaceable contoured keycaps make it easier to find critical WASD keys—even in dim light. Plus the Full N Key Roll-over on USB and 100% Anti-Ghosting mean that every key you touch translates directly into the game.
Product Features:
- Cherry MX Blue Mechanical Switches - Great gaming performance with tactile feedback and an audible click for typing.
- Key-by-Key Customizable Backlighting with Red LEDs with adjustable brightness and per key programmability to light up just the keys you need. Save the combination for your favorite game directly to the keyboard.
- Contoured, Textured WASD Keycaps - Keep your eyes on the action with easy to locate FPS keys
- Brushed Aluminum Chassis - Professional-Grade look and feel plus the rugged durability needed for hours of gaming
- Full Key Matrix Anti-Ghosting with Full N Key Roll-over on USB - Every keystroke translates into accurate gameplay¡Xeven when multiple keys are pressed.
- Detachable full length wrist rest - Soft touch design that¡¦s comfortable for hours of play and easy to remove if it gets in your way.
Specifications:
- Cherry MX Blue mechanical switches
- Replaceable contoured, textured WASD Keycaps
- Additional keys for WASD and 1-6 number keys
- Selectable 8ms, 4ms, 2ms, 1ms and BIOS mode
- Deep Red LED backlighting with key-by-key programmability to light up individual keys
- Aluminum unibody construction for increased strength, durability and rigidity
- Six dedicated multimedia keys
- STOP, PREVIOUS, PLAY/PAUSE, NEXT, MUTE, VOLUME UP/DOWN roller
- Windows Lock key for uninterrupted game play
- Product Dimensions: 438 x 166mm
- Product Weight: 1200g
- Warranty: Two Years
Only £79.99 inc VAT.
ORDER NOW
Features:-
Specification:-
- AM3+ Socket
- 8MB L2 Cache
- 8MB L3 Cache
- 64-Bit Technology
- TDP: 220W
- 32nm technology
- 3 Year Warranty
ORDER NOW
Product Features:
Specifications:
ORDER NOW
