- 18 Oct 2002
- Kuala Lumpur, Malaysia
After a bit of advice on sorting out our office's network.
Current set up is very simple :
Standard BT Business ADSL hub/modem connected to 16 port basic Netgear Switch > 1 x 16 port Netgear PoE connecting to desktop PCs (around 7) + 4 IP Phones.
Few other machines running through first switch and a CCTV NVR.
We'll be getting a new connection installed in around 1-2 months and will be looking to upgrade the overall network.
ISP will be providing the Router (Cisco 1921 + EHWIC-4ESG)
Whilst this is managed there's always a charge for adding port forwards etc.etc. so we're looking to add our own router (Draytek Vigor 2925?) and have a set up using VLANs as below :
1. VLAN 1 = VOIP : 4-5 x SIP Phones
2. VLAN 2 = General Data : 10-15 PCs
3. VLAN 3 = CCTV : 20+ IP Cameras / NVRs (accessible from VLAN 2)
4. VLAN 4 = WiFi (without access to any of the other VLANs)
The ISP was proposing to pre-configure the router as 2 VLANs (1 port for SIP phones, 1 port for remaining data) which in our case wouldn't work as the switch used for phones would also have some desktops connected.
Basically the question is, would we be better off :
1. 1921 configured with 2 VLANs - 1 for Voice - run additional CAT5 cable to existing 8 port PoE switch for Voice only, and additional switch for Desktops. 2nd VLAN into our Draytek router and the remaining 3 VLANs defined from there.
2. Our Draytek router handling all the VLANs, instead of separate voice/data switch just 1 x 16 port managed switch - 4-5 ports Voice, remaining ones data
I'm leaning towards 1 - especially in case we do have issues with VOIP the provider can't blame our own equipment, and just requires laying one additional cable.
Would appreciate any advice / input, Thanks!
