***The Vapers Lounge***
Status
Not open for further replies.
Finally upgraded from an EVOD/EGO that I was using since I started to an MVP2. Only picked it up last night, so I'm still trying to get my head around the VV/VW part of it.
Really liking it so far though.
Used to run mine at 11 watts with a 1.5 ohm coil if that helps?
Cheers
Im the same but I guess everyone likes different v/w as well. I have a dual coil 1.5 in my mvp at the moment with digbys apple and cinnamon in and mines at 9 watts. Voltage is at 4. Different juices do tend to like different settings though
I understand those numbers dont add up but I just find they work for me
Well im a week (tomorrow) vaping on my mvp 2. I have to say the iclear 30 tank that comes with it, is a gargling leaking piece of junk. However the mini Nautilus I purchased at the same time is a gem. It never leaks, has never gargled irrespective of how much liquid is in it and I can fully agree with the hype.
So thats almost a week off of cigs too but I do notice I have been suffering sore lungs.
Could be how i am vaping, the amount, the fact I am using 50/50 mix and a somewhat high-ish nicotine level.
I don't know. I hope it eases as in all honesty I have still so many juices I need to try.
Ive noticed that as well and find higher nic levels will do that to me. PG and VG levels can also be a factor
Just FYI, if you change the watts it adjust the volts. On a 1.5 Ohm coil @ 9 watts your actually at 3.67v. :)
http://www.steam-engine.org/ohm.asp
What nic %? Its unlikely be the ratio, if anything a higher PG juice will be a bit of an irritant.
Sore lungs is probably due to not smoking the fags and will pass.
Well done, stick with it:)
I found that when I first started vaping, I got a really sore dry cough for a few weeks. quality of liquids is definitely a factor, but I've found vaping in general leaves me fairly dehydrated, and that drinking more water than usual helped quite a bit
Wow... thanks for the feedback guys. The nic content is 18%. Not the highest I know. I am vaping between scopes blueberry 18% 50/50 (lovely) and GVC (probably spoiled due to the tank its in) again the same mixture and ratio.
I purposely never seek anything medically related on Google as I would be planning my funeral with the carp that is out there so it is very reassuring to hear from fellow vapors that this could possible pass.
The dehydration sounds very credible. I don't drink enough fluids as I should and when I do its most likely Coffee.
Question for you regular Fasttech buyers.
I've not used them before, generally get all my stuff from UK sellers, but put an order in a week or so ago.
I know they're notoriously slow, but none of the China Post tracking info they've sent me works, is this a regular occurrence? It's just a couple of clones no batteries, so in theory nothing that should hold it up.
Its normal, sometimes i have recieved a package before the tracking says anything at all lol.
Also if an item is not in stock, it will usually say 'ships in 5 days' etc... so you have to be careful ordering sometimes.
I know its hard, but its best to order from China and forget about it, that way when it does eventually turn up, its a surprise.
Checking the tracking everyday just winds me up lol
As said above, order and forget. Otherwise you'll end up demented by the time it arrives, lol.
My last order went in by China post, but it still hasn't been dispatched yet due to stock levels. The last China Post I ordered though was here in 5 days, so I'm not worried yet.
Destination Country - United Kingdom:Tracking Consuming:998 Millisecond
Origin Country - China:Tracking Consuming:1092 Millisecond
2014-07-30 09:49, 英国, 妥投, 英国, Final delivery, GB
2014-07-28 17:46, 英国, 到达进口互换局, 英国, Arrival at inward office of exchange, GB
2014-07-28 05:21, CAN, 交航, 英国, GB
2014-07-27 13:52, 广州国际, 出口总包直封封发, 英国, Departure from outward office of exchange, GB
2014-07-27 12:53, 广州国际, 出口总包互封开拆, 英国, Opening, GB
2014-07-26 15:55, 惠州市函件局, 收寄局收寄, 英国, Collection, GB
FAST...
Can you replace the battery in the MVP? If not it would be about 12 months then you need a whole new unit...
AFAIK yes. However the battery wont die after 12 months it will just drop off bit by bit. I can get nearly 2 days of chain vaping out of mine so even if it drops to a day its not that bad. TBH even if it died after a year you can get them for around £33 if you look about
Drop down to 12. :)
Guys, i say this with no disrespect its just sincere advice from a former smoker, and it weren't no light smoking either. Just pluck up the courage and will power to dead it straight up with no intervals or cuttin it down business, trust me you wont regret it because a lot of it is just weakness in the mind, yeah its a addiction but sometimes you just go to deal with it the hard way.
Masking it with other substances is just that, like the example of adding fragrance to a lump of turd.
Status
