- 22 Feb 2014
I have owned my ST220 for 2 1/2 years and until 6 months ago it was relatively low maintenance.
however, in the last 6 months
have paid £860 for flywheel, clutch and slave cylinder to be changed.
it recently developed a bad misfire, after replacing the plugs and leads this seems to be ok now (genuine leads were £130 as 3rd party ones were a poor fit
now there is an engine management light on (although I think this is related to the LPG system I have fitted which is due a service) (the error code indicates bank1 is running lean)
Then there is a rattle at the back end, it isn't causing any problems other than annoying me but from the knowledge I have of this car it is probably the rear sub-frame bushes.
The drivers seat has developed a bit of movement as well accompanied by a bit of a squeak occasionally.
The car has become a bit of a workhorse now as I changed jobs and am doing roughly 25k a year.
Have done some maths and if I took a loan out for around £11k and bought a 3 year old modern diesel I would be roughly £20 a month worse off but with less headache (in theory)
I don't have any money to put towards another car other than this mondeo which isn't going to be worth a great deal as alloys are ruined (common with diamond cut finished wheels
) the bodywork isn't in best of condition either.
The car drives fine at present and I don't know which school of thought I should follow at this moment in time. Given that I have just shelled out over £1k in repairs I am sort of thinking I want to get my money's worth before I shift the car on, but then I am also thinking when will it end ?
I would miss the power as well if I decided to upgrade now as I would be dropping to circa 120bhp I would imagine with a diesel that is economic enough to make the change viable.
So over to you OCUK, keep it or get rid ?
