- 20 Apr 2011
- Stoke on Trent
Hello
I have a Sapphire Radeon R9 290 Tri-X OC (in my Son's PC)
I also have trixxx installed (from Sapphire) to help with OCing and fan control.
Also have installed latest CC and drivers.
At random times the GPU fans got to 100% and will not change from this until a reboot.
The GPU is not showing as too warm and the fans have just switched to 100% at 50c (under no load).
Even if i now try to manually control the fan speed (in Trixxx or CC) nothing happens and the fans stay on 100%. only a reboot seems to work.
This seems to happen at random times, even when the GPU is hardly in use (just general web browsing, etc).
Current GPU temp is showing at 46c (with fans at 100%).
Room temp is around 22c.
FYI:
The PC has just had a full format (2 hours ago) due to the PC being full and messed up and random BSOD (so my first step at curing the BSOD was a full format).
(no more BSOD yet, so hopefully this part is cured)
The Sapphire Radeon R9 290 Tri-X OC is only around 3-4 months old, bought from OCuk.
The PC has a goodish case and goodish ventilation (never had any overheating problems).
There is currently no OC on the CPU or GPU (other than what it is shipped with).
All other components are bought from OCuk over the past few years.
Any ideas what this can be?
Maybe a driver issue?
Faulty GPU?
GPU heat-sync not fitted correct?
Thanks for any help
Jon
FYI:
Faulty GPU?
Thanks for any help
Jon
