Spec out your perfect phone!
14 Apr 2014
Sunny Sussex
I'm interested to see what you'd define as your 'perfect' phone. Many people have different preferences, especially when it comes to screen sizes!
It could be from scratch or taking the best from different phones. Personally, mine would be:
HTC One (M7) frame with a textured back for grip (or the new Moto X) - I love the rounded feel but also the grippy finish on the S5
Front facing speakers
Samsung's new Octa core processor as it's more efficient than the 801 from what I've seen
4.7 Inch screen, maybe 5 inch if it means bigger battery. 1080p AMOLED
Oppo's charging capabilities
OnePlus' pricing
S5 camera, maybe the nokia 930's camera.
64GB Storage
Removable back for battery swap (or how the HTC Desire HD did it with just the bottom bit being removable.
How about everyone else? What matters to you most in a smartphone?
13 Mar 2011
Bada Bing
m7 frame in silver, but larger
6" edge-to-edge display (think Ascend Mate 7)
a 1080p display (nothing too ridiculous as i want a decent battery life)
A silent switch like an iphone
No other buttons apart from a power button
wireless charging
always listening chip like moto x
IR blaster through the power button (reduce busyness of the body)
Caporegime
18 Oct 2002
London
Xenon flash
5" 1080p Super AMOLED+ RGB screen edge to edge
SD card
USB 3
High quality all round camera sensor
Premium frame
A large battery but also software/components to get 2 days of heavy use
32/64Gb internal storage
64bit Snapdragon 810
4Gb RAM
Water/dust proof
Removable back
Front stereo speakers
30 Sep 2005
HTC One M8 Body
5.5" QHD Display
Snapdragon 810 64bit
16mp+ Camera with OIS (Dual Flash)
4GB Ram
64GB Storage
SD Card Reader
Removable Battery
Stock and Unlocked Android L (however, whoever makes the phone needs to apply a really great skin as the google android l icons are shocking)
Factory fitted glass screen protector
and a personal request, a micro sd cable which can be plugged in either way, magnetised with a small proximity led light
also, perhaps having easy to replace parts such as rear back and side strips. That way, if you get any scratches you can change it (or a colour change if you're bored)
Man of Honour
11 Mar 2004
Lumia 930 look
Htc m8 stereo front speakers
1080p 5.5" sapphire screen, with super sensitive touch & glance, using what ever screen is best for sunlight readability and low reflection.
Lumia 1020 camera, ois, dual flash etc. Or even a newer upgraded version
Water and dustproof. (so most likely no removable back, not an issue if the battery is good)
Always listening chip like moto x
Snapdragon 810
4gb ram
64gb memory
micro sd card
NFC
Wireless charger
Electronic Compass
~4000mah battery, preferably something like Toshiba SCiB that can be charged to 80% in 10mins, they have slightly lower energy density but I don't think it's much.
Dedicated buttons for back/home/search, as well as volume, power, camera
Available with wp8.1 or android. Should also come in a 4.7" variety for those who like a smaller phone.
7 Apr 2008
Nothing much that my phone doesn't already give. Perhaps a better quality camera. And a longer lasting battery.
Same for me, we're at a stage now where there isn't really much that the very latest devices can offer that are truly "revolutionary" (for want of a less Apple-esque word). I'd say an iPhone 6 with a slightly smaller display (4.5" or so), slightly thicker to accommodate for a bigger battery (2750mAH or so?), iOS 8 (if it shapes up as expected) and...that's it really.
Caporegime
13 Jan 2010
Llaneirwg
5.5 inch screen
1080p
Bright enough to use during sunny days (very hard)
virtually no bezel (need some for practicality)
Kevlar shell - like Motorola razr
Hard camera button (I hate not having this as I do now) + volume + power
At least 32gb internal
Micro SD
Full 4g
Stereo front facing good quality speakers
Nice DAC
Fm receiver
Epic full rgb led.. Ideally front and rear facing and a strip.. Perhaps across the top bezel
Charger port on side (had this on my old phone... So much better than bottom)
3gb ram
Happy with 801 cpu
Android stock
Tap to wake (love this)
Decent camera (never had this) and where flash actually helps!!
3500mAh battery or more please
Man of Honour
11 Mar 2004
that the very latest devices can offer that are truly "revolutionary" (for want of a less Apple-esque word). y.
Although I agree, why can't one phone just have all the good specs. Rather than split between several phones and about 4 manufacturers.
13 Apr 2013
La France
We won't see another revolutionary mobile phone until there are revolutionary changes in battery and/or display technology.
The only caveat to this would be if wearable devices became the primary interface and the phone becomes simply a modem and battery pack.
Caporegime
21 Jun 2006
5-6" OLED screen
24+ hours of screen time before battery dies
64+ GB memory
13+ MP camera
wireless charging
no thicker than a nexus 5 whatever that is
build quality of nokia
runs stock android
plus all the other things you get as standard like bluetooth, 4G, etc.
Man of Honour
13 Nov 2009
Northampton
Note 3 with
Smaller Bezels, Aluminium body, larger battery.
For me the Note 3 is almost perfect. Battery life is a funny one as I'm sure I was getting 30% screen on time when I first got it to now
18 Feb 2006
4.7-4.9" OLED
3000mAh+ battery
32-64GB storage
2GB RAM
Stock Android
8MP camera with awesome low light performance
lightweight aluminium build
Approximate dimensions:
130 mm H
65 mm W
8 mm D
12 Nov 2003
Skipton
1080p 5" edge to edge screen
2+ days battery life with reasonable usage
Fairly robust and waterproof
32gb+ storage
2gb+ ram
Close to stock android.
Good camera, 10Mp+
1 Jun 2007
4.7-4.9" OLED
3000mAh+ battery (2500mAh will do for the size/weight)
32-64GB storage (128GB for me :D)
2GB RAM (3-4GB if the screen is 1080p)
Stock Android
8MP camera with awesome low light performance (40mm lens with OIS)
130 mm H
65 mm W
8 mm D
No more than 130g
This.
