Best budget gaming mouse?
31 Oct 2011
Up until now I've been using a razer naga but it's started scraping on my mousepad so I'm looking to get a cheap replacement. Anything up to about £15 would be ideal. Any recommendations?
Thanks guys
Replace the feet or a steelseries kana can be had for around £15 on certain auction sites that are new...i picked up 2 of them the other day as i had one previoilusly and loved it
Thanks guys
If you like the naga you could get some cheap teflon tape (under £2) or get some replacement feet.
I used teflon tape on both of the deathadder mice I had as the feet wore down so quickly and it felt smoother than it did when they were new :D
Wouldn't like to suggest any mice as it's really personal preference and depends on your grip style, number of buttons needed etc
http://www.overclockers.co.uk/showproduct.php?prodid=KB-006-GI&groupid=702&catid=23
This.
Ive used it for like 2 year just upgraded today and its done me well for the price! I had to upgrade as i borked the mouse buttons when i smashed on my desk in rage!
I've got Gigabyte M6900 and I thought it was the very nice mouse as well ;-) Until I saw:
* hangups in games during very fast movements at highest resolution (re-inserting helps),
* mouse not working at all sometimes after boot (re-inserting helps),
* pointer goes up when slide mouse down (re-insert helps).
Have you ever experienced this with your M6800 ?
I previously used an Gigabyte M6900 and had none of those problems, I had a Razer Copperhead before that which sometimes(though not very often) required re-insertion after boot though.
