Steam ~ In-Home Streaming
6 Jan 2013
Rollergirl
I've been trying to get this going but having issues. The screen on the remote PC judders and flickers constantly. Has anyone else encountered this?
Host PC is 4670k with GTX670 SLI.
Remote PC is 3570k with GTX660
:confused:
It really needs to be direct cabled imo. Wifi just won't cut it imo, I have about 20 meters of cables under the skirting boards to my streamed laptop :) Wifi never worked for me either, I think it is just to much.
BT home hub is probs the issue for me then. Only works if I use a wire, well it does work via wifi but it is really bad for me. Does not effect me anyway as the whole house is wired.
I used powerline too, and I've never had issues with powerline in the past.
I'll try removing the GPU and running it with onboard graphics, just to rule out a driver issue.
I'll let you know how it goes.
