The "New Gear/Willy Waving" thread
13 Dec 2004
Stoke-on-Trent
I've highlighted one of its short comings.
And it is hit and miss with ETTL, because of 18% grey metering, it won't fire that much a flash behind the subject, because of the whole black lit thing. It is actually very difficult. It is much easier to have the flash off camera going off a set value in manual and ETTL the front.
So I set 2 580ExII's up on manual with 2 flex TT5 receivers, then on camera I have a MiniTT1 with another 580EXII on top on EETL.
Camera set to <1/20th - f.8ish - 800+ISO - 2nd Curtain sync - and every night shot will be perfect......
AC3 seems like a waste of money then really, is there anything that I can replace it with that will still fire the Flex's off 2nd curtain? And give me the ability to change the 2 manual flash powers without walking over to them?
28 Feb 2009
I just got the Tokina 11 - 16mm 2.8 Is it any good? :p
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
AC3 is useful in a studio, and lazy...
28 Dec 2003
Yes it's the best UWA lens available for crop without a doubt.
Very debatable. It's a good lens and the f/2.8 aperture is nice but the Canon 10-22 goes wider, has more range, better focusing and just edges it on image quality.
EDIT: Unless we're talking about Nikon, then I don't have a clue lol :p
19 Jul 2004
Shoreham by Sea
Apparently the new 10-18mm is sharper and cheaper but with less range than the 10-22mm so that's also worth throwing into the mix :) Has similar variable aperture but also has IS which is definitely a plus.
Depends if you really want that F2.8 aperture I guess
16 Jan 2008
Got this just before I went on holiday for 2 months.
Canon EOS 70D
Canon EF-S 18-135mm STM (f/3.5-5.6)
Canon EF-S 10-22mm USM (f/3.5-4.5)
Cokin H250A ND Grad kit
Cokin H270A Full ND kit
Absolutely loving it. Just need to find a case now. Borrowed my dad's for the holiday.
Also, next lens looks like it'll be the EF-S 24mm pancake lens if the price is right.
(I've also got a 64GB SanDisk Ultra SD card. The two 32GB SanDisk Extremes that I ordered direct from Amazon turned out to be counterfeits...)
22 May 2003
Are you going hipster on us Rojin?
I do actually like the bag, doesn't scream photographer, you'd have to make sacrifices on what you take though. The all round zip is useful.
19 Oct 2002
Gloucester UK
Nah, I would've bought an Ona :D
It easily fits the two bodies with 23mm and 56mm mounted with hoods ready to go. In the middle I can put a 50-230mm, or a couple of other lenses. If I want to take more lenses I can go with just one body. If I need to take it all I've got bigger bags :)
