I7 4770K + mobo or Radeon R9 290
9 May 2013
Sheffield
Ok guys, you can see my current specs. I feel an upgrade coming on, but which is it to be?? I appreciate i'll need to upgrade my PSU if I go the graphics card route. Cheers in advance for any input.
Hi,
If your buying new, then i7 4790k and z97 is best to buy now. If you budget is not limited then x99 is a enthusiast level with multi core options. :)
Do you have a budget in mind ?
You still have a pretty decent system there. Does it struggle with any games ?
I would get a bigger SSD if you only have a 60GB one. Your 650W psu is fine for any single gpu, assuming it is a good make.
I just upgraded from the crosshair v formula z + FX8350 sold them for £200 within 24hours of advertising.
Purchased Maximus VII formula and 4790k and the difference it has made has blown me away !
One or two surprise me a little. I have to knock the detail down in Far cry 3 more than I'd like, but others are absolutely fine. Tomb Raider's benchmark maxed out including TressFx averages out at 55.3fps for example. Not too shabby. Drivers up to date BTW.
It's interesting what you say about my psu, because all the R9 290 cards I've looked at recommend more than 650W.
That is very interesting. Do you have any examples of just how much difference it's made, and what GPU do you have? Also slightly off topic, did you reinstall your OS?
