Ive got a reference cooled 780ti from MSI fitted into a mITX case (I know ref cooled cards dont run as cool as aftermarket ones but I wanted rear exhausting due to my mITX setup).
Whenever I play something like FarCry3 the temps shoot up to 83 degrees within a few minutes and then drop back to the high 70s. It never goes above 83 though. I dont seem to get any drops in performance either, although I do have shocking eyesight and have spent the last few years console gaming so Im used to poor quality!
The rest of the system runs nice and cool (45 degrees under load on the CPU with a H100), system temp at 37 degrees (one large intake fan, one small exhaust fan). There is nothing blocking the card exhaust but I'm a little worried about the high temps. I read online about using MSI afterburner to set a fan curve for it which I have done but when I check the fan in HW Monitor its saying its only spinning at 60% on the GPU.
Is there anything I could do differently to improve the cooling? Any alternative settings I could use in Afterburner to stop it getting so hot? Or is it simply poor case choice thats responsible?
Thanks
Thanks
