3570k Cooling Suggestions
18 Sep 2005
Hi Guys,
What to replace the stock cooler on my Intel i5 3570k, I don't have plans for an extreme overclocking but would like to go a little higher, currently running it at stock volts at a 4Ghz clock speed. However I do want my system to be as 'silent' as possible, with that in mind would cooler would you suggest?
Currently looking at...
Be Quiet! Shadow Rock 2 CPU Cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-006-BQ&tool=3
Or perhaps this although I don't really want to speed £50...
Noctua NH-U12S Ultra-Quiet Slim CPU Cooler with NF-F12 Fan
http://www.overclockers.co.uk/showproduct.php?prodid=HS-025-NC&groupid=701&catid=2330&subcat=2346
Thanks for looking :-)
I use the antec 620 AIO cooler on mine, works a treat. I prefer AIO wc'ers much more tidy and easy to work with.
I run 2x Scythe Gentle Typhoon 1850RPM fans on the rad and use a fan controller to reduce the speed on fans to 1200rpm its perfectly quiet.
Megahalems is doing a fantastic job on my build, would happily recommend for anyone who want quiet air cooling, with no liquids involved.
Ill give you that, its a nice cooler, but i found the strain of the cooler against the motherboard, especially if the cooler is massive is a risk not worth taking... AIO hydro coolers have proven themselves to be a match, or in most cases, better than air coolers out right
