Poll: iPhone 6...
Which iPhone have you bought/ordered?
  • iPhone 6 16gb
    Votes: 82 15.1%
  • iPhone 6 64gb
    Votes: 223 41.1%
  • iPhone 6 128gb
    Votes: 49 9.0%
  • iPhone 6 plus 16gb
    Votes: 18 3.3%
  • iPhone 6 plus 64gb
    Votes: 109 20.1%
  • iPhone 6 plus 128gb
    Votes: 62 11.4%
  • Total voters
    543
I used to complain about big phones ages back, I only have small hands and got a Note 3 and tbh you don't even notice the size it becomes normal, you certainly notice the extra screen size you have.
The 5s screen has always put me off Apple as they are just too damned small to enjoy doing things on so the 6+ was a no brainer for me to order.
Just received my confirmation mail from cpw and they have taken the money now. I ordered it Monday and for my first mail soon after, was told yesterday they waswaiting for ee to finish checks as they are a bit busy atm. Also mentioned if they cannot fulfil order they would contact me.
This just keeps getting better :D
After being told my order doesn't exist, I now get this today. Ashley made my brain explode
You never go through the credit check has yet!!
Yup. I would love an iPhone+ size device to replace both iPad and iPhone but need something I can fit in a trouser pocket.
Same. I really wanted to get an iPhone 6+ but in the end I went for a 6 because I don't think I'd comfortably get the 6+ in my work trousers.
See how I feel when I hold one but at this stage I'm happy I went for the 6 if the battery life is only half a day shorter :)
That's what put me off. Made the template with cardboard to actual dimensions, put it in my pocket and it stuck out and dug in when i sat down. Would have to remove it from my pocket to sit down...
I showed people at work and one of the girls said it wouldn't be a problem, because they rarely have pockets and put things in their bags/purse... Which is completely fair enough, most girls would do this so wouldn't be a problem at all.
So there you have it, the iPhone 6+ is for girls.
Hence why I call the 6 plus, S4/5 and Note series handbag phones.
What i don't understand why did they put the 6 with a 4.7" screen with the same PPI as the 5s which has a 4", it needed a slightly higher rez/ppi for the bigger screen.
http://i.imgur.com/ymqhRIR.png[IMG]
You never go through the credit check has yet!![/QUOTE]
Out of interest why do you keep going on there to talk to them? Amusement value?
