I just got round to building my i5-4670k/Asus Z97-A system with the Scythe Kotetsu HSF the other day. Did a build for my Dad with the same mobo/CPU but the Hyper 212 Evo HSF a couple of months ago and that works fine at [email protected]
My system at 3.8Ghz and in High Performance mode to keep the CPU at a fixed speed/voltage (monitored with HwInfo)
Idle:
CPU Fan: 780 PM
Chassis Fan: 1000 RPM
CPU: 41c
Cores, 42, 38, 40, 36
The fans were a bit noisy like that so I manually edited their profiles in the BIOS.
CPU Fan: 742 RPM
Chassis Fan: 318 RPM
CPU: 46c
Cores: 45, 42, 44, 41
Aida64 Stess Test for 30mins:
immediate:
CPU: 60c
Cores: 59.5, 59, 59, 54
after 30mins:
CPU Fan: 940 RPM
Chassis Fan: 325 RPM (I had this tied to the motherboard temp, so it didn't speed up, I changed it to follow the CPU speed after this)
CPU: 60c
Cores: 60.2, 59.3, 59, 54.5 (Avg), 67, 67, 66, 61 (Max)
immediately after stopping Aida64:
CPU: 47c
Cores: 47,44,44,41
I tweaked the fans a bit more and added a Scythe 120mm intake fan.
Ambient temp was 24c.
Idle:
CPU Fan: 780 RPM
Intake fan: 440 RPM
Exhust Fan: 370 RPM
CPU: 40c
Cores, 41, 38, 39, 33
Aida64 for 30mins:
CPU Fan: 935 RPM
Intake: 435 RPM
Exhaust: 544 RPM
CPU: 55.8c (Avg), 62c (Max)
Cores: 55, 54, 54, 50 (Avg), 62, 62, 61, 56 (max)
I wonder if the fact that core 4 is running a bit cooler than the others indicates that I haven't applied the TIM very well, or if that's just normal?
For comparison, here's a screenshot from testing my Dad's build (with the Hyper 212 Evo) also running at 3.8 Ghz but at 1.173v, whilst mine is at 1.1v. His CPU fan was running at 1000 RPM and there was an intake fan and exhaust fan running at 792 RPM and 969 RPM (not sure which was which).
Next, I overclocked to 4.4 Ghz @1.225v (still running in High Performance to lock the clockspeed). Ambient temp was 25c. I tweaked the fans a bit more.
Idle:
CPU fan: 820 RPM
Intake fan: 670 RPM
Exhaust: 530 RPM
CPU: 43c
Cores, 43, 40, 41, 36
Aida64 for 30mins:
CPU Fan: 1080 RPM
Intake: 715 RPM
Exhaust: 870 RPM
CPU: 66c (Avg), 73c (Max)
Cores: 63, 62, 62, 56 (Avg), 72, 71, 70, 66 (max)
immediately after stopping:
CPU: 44c
Cores: 44,43,42,37
So it doesn't seem to be doing much better than the Hyper 212 Evo in my Dad's build. Here's the results with that at [email protected] running Aida64 (ambient was 3c higher at 28c):
Even taking into account he's using a different case and fans, which were running at different speeds to mine (his vs mine: CPU 990 RPM vs 1080 RPM, Intake 1080 RPM vs 715 RPM, Exhaust 915 RPM vs 870 RPM), I was hoping for better results with the Kotetsu. Comparing the max. core temps:
His: 77, 76,73, 69
Mine: 72, 71, 70, 66
and taking the +3c in ambient temp into account, the decrease is -2c for cores 0 and 1 and 0c for cores 2 and 4, which could just be down to my more open Coolermaster HAF XB case compared to his NZXT Source 530 (with top vents blocked off).
It does seem my 4670k just isn't as good as my Dad's one sadly. At [email protected] it was fine with Aida64 stresstest but BSOD running ArmA3, just on the menus not even running a mission, with "WHEA Uncorrectable Error".
I bumped it up to 1.25v and it's fine now. I might be able to decrease it a bit still from there. Even though I'm using the superior Scythe Kotetsu HSF compared to my Dad's Hyper 212 Evo, temps were about the same at [email protected], so it'll be running hotter at 1.25v. I haven't bothered running Aida64 @1.25v yet though, so I'm not sure exactly how much higher but ArmA3 only pushed it to about 60c, so it's fine for normal use.
I was hoping to overclock it a bit higher than 4.4Ghz but it's not the end of the world if I can't. I do want to make sure the HSF is cooling properly though, so I'd welcome any advice as the Kotetsu doesn't seem to be doing as well as it should.
I have to admit, I wasn't entirely happy with my TIM application. The guides suggest a 1mm vertical line but that's tiny and seems impossible, as pushing the plunger on the syringe (MX-2 in this case) doesn't give great control and it tends to come out with a bigger amount than is ideal, so I just try and spread that down in a line, adding a bit more if it starts to run out. In this case, I ended up with a bit of a gap in the middle, so added some there to make sure it was covered. I took a photo of it just in case it didn't seem to be performing very well:
I don't think my application when doing my Dad's build was much different though, except for the extra blob in the middle as I think I was able to just spread it down in a line in one go in that case.
Idle:
CPU Fan: 780 PM
CPU: 41c
CPU Fan: 742 RPM
CPU: 46c
immediate:
CPU: 60c
after 30mins:
CPU Fan: 940 RPM
CPU: 60c
CPU: 47c
Cores: 47,44,44,41
Idle:
CPU Fan: 780 RPM
Intake fan: 440 RPM
Exhust Fan: 370 RPM
CPU: 40c
Aida64 for 30mins:
CPU Fan: 935 RPM
Intake: 435 RPM
Exhaust: 544 RPM
Idle:
CPU fan: 820 RPM
Intake fan: 670 RPM
Exhaust: 530 RPM
CPU: 43c
Aida64 for 30mins:
CPU Fan: 1080 RPM
Intake: 715 RPM
Exhaust: 870 RPM
CPU: 44c
Cores: 44,43,42,37
His: 77, 76,73, 69
