GTX 980 / 970 Discussion
19 Dec 2013
Penrith, Cumbria
The only mistake I see is that you are buying current cards to try to future-proof for 4K (which you probably won't upgrade to for...I dunno...may be another 2 years may be?)
IMO anyone that want proper performance for 4K, they should really wait for the 20nm card at least, unless they are planning on going at least Tri-SLI/Tri-Xfire in the future, as a pair simply don't have enough GPU grunt to push 4K in any slightly more demanding game...not without sacrificing graphic quality at least.
I get your point. To be honest, I'll probably go for a 3440x1440 first. I'm just waiting for more manufacturers to release their version. I'm not too bothered about 4k (yet) as anything above what I currently have will be an improvement.
OcUK Systems
OcUK Staff
16 Nov 2007
Stoke-on-Trent
A new Nvidia Graphics card is cheaper than the monitor so it makes sense to change ;)
Plus GSync is awesome! i never thought i'd hear myself say that when I first heard about it
I'm not one to recommend one team over the other, my card history has gone from one to the other over the years but he's spent a lot of money for a feature that he can't use unless he switches.
6 Feb 2010
Yea I TOO think that 3440x1440 is probably the best way to go, considering the balance between improving the gaming experience and graphic requirement.
1 Apr 2014
Aberdeen
Patience, guys, patience. The world isn't ending. I'm going to have to wait anyway as the 8 GB cards aren't going to be in the initial release. Still, I'll be able to compare the 8 GB cards with the Titan 2 cards.
Permabanned
14 Jul 2014
I'm waiting too mate. I would rather get a dual card or a 8gb model because my case is too small. Parvum 2.0. It can do SLI, but it would be a tight fit not sure if I would be ok for air cooling with a max vii gene with my case?
