- 11 Aug 2012
- Wales
Had my Haf X for the last 2 years, not heard any clicking problems, and this thing has 2x 200mm fans and a H100 up top.
Ran a quick experiment this morning. Booted PC up and it started clicking again - ran AC4 to warm it up and the clicking stopped 6 minutes after boot.
Yes I knew that already - it's the fan blades colliding with something inside the case, which I think I've narrowed down to the strip of metal that runs across the top of the case underneath the fan.
Ah ok .... I know the ones you mean ... maybe a tug down on them might do the trick![]()
Yeah, tried that - they're pretty stiff, and it's an awkward angle when you're inside the case. It's only the rear one catching. When I get a spare half hour I'll take the top of the case off again and push down on it instead![]()
As soon as I get home from work ill take a photo as I am on my mobile atmYeah.. I own one, just can't work out how to fit it. What have you screwed it in to?
