Was looking at a brand new 64 plate white BMW in the street today, and you could distinctly see orange peel type markings in the paint.
What causes it, and why do manufacturers think it's acceptable?
The orange peel on lots of late reg. BMWs is a disgrace tbh, my E93 isn't too bad but it's certainly not a great finish.
One of the reasons I probably won't be purchasing a BMW as my next car
My Honda was so bad I bought myself a DA polisher (paint was soft enough to be corrected by it) but the paint on my e92 is so hard I've only been able to very slightly improve it
If the clear coat Is flat the colour underneath will look flat
Read a diy spraying guide where they tell you to sand with fine paper before clear coating for example . everyone thinks this step is madness and that you will see the dull hazy colour through the clear but the clear fills the high and low spots then once flat itself can look great
Obviously if its particularly awful you have a big risk of striking through the clear though
Regarding BMW paint what do you expect when the 3 series out sells the Mondeo. BMW have been living off their prestige rating for some time now.
BMWs get called out on the orange peel frequently yet the MINI paint appears much flatter.
This is a broad sweeping statement but I have always found the Italians and French to be the best regarding paint. Especially over time.
Japanese paint tend to be very soft which is a good thing for correction but a bad thing for wear.
