MSI GAMING NOTEBOOKS
Keep us update, personally feel laptops need to be targeted at £600-800 range, £600 as an entry level into gaming laptops and £800 as entry mid range and etc imo this an open market anything above 1k i just feel get a normal PC instead or just puts people off buying atleast from my point of view thats how i feel.
Most laptops that cost around £800 all seem to lack something either it has a bad cpu, or no ssd, or no OS or even a rather poor gpu like the 840/850m. 860m seems to be decent enough according to some reviews i dunno what the normal prices are for R9 M290X but amd usually tends to be cheaper than intel and that imo is a good gpu.
Hi,
I think the issue is that, the price point have to be met, and the most expensive parts of the NB (besides our chassis which are built and designed in house with great features) are the CPU & GPU. Something has to give to get to the price of £800ish
I will discuss with Gibbo & OCUK tomorrow and see what we can do for you guys!
ARJiBEAR
Hi,
ARJiBEAR
Sounds good mate, if you can get an i5 with 860m atleast or + or R9 M290X (dunno which one is cheaper) at that price level. Your got yourself an amazing laptop, also an ssd lol.
Looking forward to what you guys can come up with tomorrow.
Aye keep us in the loop wanting to buy a mid end machine for gaming while i work away from home. Like the look of MSI stuff as i tend to use your GPUs in all my main rigs.
Hi Meaker....
I feel you may know things that you are not supposed to know.....
Some of the above is already happening....watch this space!
ARJiBEAR
The MSI NOTEBOOK UK Team
It was totally without info but the gs30 did make me laugh.
By the way the gt72 stuff got delayed for obvious reasons, you can still look forward to my work on that ;)
any updates?
OCUK will be having some decent gaming units between £749-999 from October on-wards.
They will range from 840M - 860M (some with an SSD).
More details will be revealed once the set ups have been done.
Hope this helps!
ARJiBEAR
Hope this helps!
ARJiBEAR
no R9 M290X ? also is it easy to install an ssd to the laptops and transfer windows to it? will we see some i5 or all these going to be i7s (most seem to be i7s) just asking this as id like an i5 with a 860m at a decent price
When I was looking for a gaming laptop, what was important to me were:
- 1080P screen
- High end GPU
- High end i7 CPU
I preferred lower RAM and Hard Drive as I wanted to upgrade those myself by saving on the cost of the laptop and shopping around for the best deals on those components.
At the moment R9 M290X are not on the cards, but possible towards the end of the year/early next year we may have a unit.
Some units will be I5 but not the "U" version.
Most will be I7 :)
ARJiBEAR
Hopefully there is an option similar to the MSI GS60-2PL available in some other regions, which has the GTX 850m with an i5 processor, SSD & normal HDD combo and an IPS screen.
I am looking for a lightweight chassis and processor which is good for battery life, but also has a reasonable graphics card and high quality 15" display. This seems to fit the bill, but it's a hard spec to find with out spending insane amounts of money :/
Yep that's the problem I'm having, I'm looking for something similar for around £850 but doesn't seem realistic.
Hi all
I can confirm the GS60 2PL will be available, but not at the price point you have suggested.
The GS60 notebook is a very high end chassis. The spec suggested will be available in an GE 2pl at approximately the price you said above.
Regards
ARJiBEAR
What I'd really like to see is a decent fx-7600p laptop. (Yes I'm an amd fanboi, deal with it!)
By decent what I mean is.
1080p screen (non-touch)
fx-7600p
probably an r7 (or maybe r9) discrete gpu to (more on this later to do with TDP, but the choice between r7 and 9 also depends a bit on how/if crossfire works with onboard && discrete).
2133 Mhz memory (or at the very least 1866, none of the 1600 Mhz rubbish I see in current fx-7600p laptops.)
SSD
Now the stuff about the TDP has to do with form factor. I'd like to see the 7600p in the smallest possible box, like 11-12inch screen (but 1080p) of course there's no point making the screen smaller than the box, but the idea is to have an ultra-portable gaming laptop. My understanding is that the size of the box is the main limiting factor on TDP, and thus if you can't extract more than 35W of heat from an 11inch box, then you won't have the heat headroom for a discrete GPU as well.
This might lead to a pair of laptops, one with no discrete GPU 11-12inch and it's big brother 13-14inch with a discrete GPU.
The deal breakers for me on this would be less than 1080p screen and slower than 1866Mhz memory.
The point is to get the best out of the apu and see how HSA works if given the best conditions available to it.
I'm interested in the technology, not just in getting the 'best' laptop.
The r7 can work in crossfire with the onboard r7 so you potentially get more graphics power (and enough cpu power) for less power (in watts and heat) thus enabling a smaller device.
I've not spent enough time looking at power consumptions to be 100% sure that fx-7600p + discrete r7 beats an i3 + whatever, providing better fps at the same settings for cooler running, but I suppose that's what I'm hoping for.
Suffice it to say that I like the idea of HSA and would buy a laptop such as I describe.
I7 4810 is a good start or at least have mainboards that allow upgrades to future chips.
GTX 980 is another desire, though I know the NDA is still up on that one.
17inch 1080p IPS screen would be very nice, I know no one is doing them right now from the looks of it, but I can dream.
I've got no idea what people think they will use higher resolution screens for on such a small screen, on a gaming laptop, 3k and 4k screens aren't better or more useable, they are the exact opposite, especially on a gaming laptop where scaling down to 1080p just makes stuff look awful. Perhaps it's the ipad effect where consumers think the bigger the number the better.
16gb of ram is plenty for all our gaming needs.
Dual SSD option is great to have, no desire to raid personally as I see more benefit from running os drive and game drive.
Optimus is nice if done right or if the system has a switch to lock it to a certain gpu. Optimus is awful if done wrong as some of your competitors have and it causes problems in games, namely diablo 3.
Ability to open it for ssd and ram upgrades without murdering our warranty.
SLI I see as utterly useless, and completely undesirable. Especially so when your competition is telling customers they cannot upgrade gpu drivers without causing thermal problems in one thread and then boasting about how fast their sli setup is in another. But even SLI done by a sane company like MSI I still see as a compromise with profiles and drivers.
Those 980gtx mobile parts are single digit percent slower than a desktop standard 780, if that isn't enough performance in a laptop we probably need a desktop.
I think MSI is getting almost everything perfect right now personally.
Just please bring out a 4810 with a 980 in the coming months and i'll be quite likely to buy it!
I was at first thinking about building an MITX for my casual gaming (working in london tiny room) and for lans and stuff, and just read 980m is about to be announced and performance seems to be up there, MSI please release a model with 980m asap and take my money!!!!!
