- 10 Nov 2006
- Lincolnshire
Thinking of swapping my F12's which I use as case fans for SP120's to move a bit more air into and out of my case, however it seems the F12's move more air?
The F12s are insane, there isn't a lot out there that will beat them.
What is your case BTW?
I was doing some experiments last night and found you get considerably more airflow if you remove the mesh strips on the top and front panels of the case. They are attached by crosshead screws.
Seeing as I cannot see the back or front mesh I have removed them and left the visible strip in.
If you want fans that are good at focusing airflow at certain points/areas of your system. Consider the silverstone air penetrators. Excellent in situations like xfire/sli where you want to push air between the cards.
