- 11 Aug 2014
- Wiltshire
Hi all,
I'm looking to replace the plastic hose clips on my loop as I don't like them nor do I trust them. Thought I would replace them prior to building the internals up. My girlfriend bought me the Phanteks Enthoo Primo pre watercooled from OCUK for my birthday (she's a good egg) so obviously I'm going to need to drain the fluid and then replace the hose clips.
The water loop installed is:
XSPC RayStorm 750 AX360 WaterCooling Kit
Am I right in thinking these compression fittings are the correct size to replace the clips with?
XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome)
Also does anyone have any advice for draining the loop and flushing the system out so I can replace the blue coolant with a red.
And finally, to save opening several threads am I right in thinking that the current pump and rad would probably be slightly too weak to complete a loop with 290x in CF? The hardware part I'm fine with, it's the watercooling I'm new to :/
Many Thanks
Many Thanks
