- 30 Nov 2011
Will a non reference work ok with a reference card in sli?
Yeah, some of the multi fan cards have issues when you use them in the top slot, with another card below, so in sli the top card is better off being a reference type, but the bottom card of the two should be fine being a nonreference type
It has you covered for all bases then - you get a better chance of a high clocking single card now, an then the option to either sli or upgrade later
