Keep your card. Undervolt it to lower the temps. And as someone else said, you would be better off changing the cooler, than selling the card at loss to get the GTX970.
After the 20nm cards are out from both companies, then make a decision if worth to change it. I doubt we going to see any major performance boost, until late 2015-early 2016 cards gen.
5 fps more, on some game while using the ancient 13.12 drivers on the benchmarks, doesn't mean anything.
Even the GTX780/780Ti cards are not as bad as benchmarks showing against the 970/980, since the significant majority use drivers before the April ones, which gave a big flat 10%+ performance overall to those cards. (I had a 780 until 2 weeks ago.....)
I figure the wider data bus on the 290x would help, or am on the wrong meds again ?
You're right as that would normally be the case, but it seems the new NVidia cards can handle higher resolutions just fine using a 256-bit bus. Good work from NVidia when it comes to efficiency![]()
Any advice on undervolting? I've never done that before.
Im here to help.Its the Corair CX600 Builder Series.
4 way @4K the 290Xs are faster than the GTX 980s, this is probably due to the heavy workload and the 512bit bus on the AMD cards.
Links of benches for this?
Very few benches yet but there was a 4 way review done the other day, http://uk.hardware.info/reviews/5623/nvidia-geforce-gtx-980-sli--3-way-sli--4-way-sli-review. But on there at stock my 290Xs were 8fps faster in Thief using max settings and Mantle, the other benches they ran were poor as well but without knowing what operator input there was it is difficult to compare.
Also three of my 290Xs thrashed 3 of Gibbos very overclocked 980s on Firestrike but this could be done to the drivers.
So far 3 and 4 card performance on the 980s is not very impressive, more so as the resolution increases but we need to keep an open mind as this could change with the drivers.
The SLI scaling does seem to be off in a few benches i have done at 1440p, hopefully its drivers. I seem to get much better results single card atm. Or perhaps its bandwith capped.
This is only with 2 cards but in Batman Orgin my scores where disappointing even with overclock, but I did a sleeping dogs bench that seemed very good.
Could it even be the PCI lanes as I have a 4770k ?
i would because the 280x (at least the ones ive used) are complete **** I absolutely ****** hate them.... next card is definitely a Nvidia...probably the 970.
Depends on how important is cooler running and lower noise level (the 970 won't be noticable faster than the 290) to you, and if it is worth spending £100-£120 extra after you sold your card.I'm debating whether to ditch my sapphire 290 reference for a nice 970. My 290 only cost me 194 squids with warranty. Don't think i'd lose much on it?
