** RAIJINTEK TRITON - A NEW TAKE ON AIO COOLERS **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Designed in Germany the Triton from Raijintek is a new take on the AIO Cooler formula that has been growing very stale over the past 5 years.
Gaining massive attention at Computex 2014, the Triton has been featured on many tech websites due to its eye catching appearance and unique design.
The Triton is a refillable reservoir/block combo that mounts to any modern CPU socket and is linked to a performance radiator.
Triton comes with different coolant options in the box and is compatible with our entire range of Watercooling fluids if you want a more custom look.
Raijintek Triton AIO Water Cooling Solution @ £69.95 inc VAT
Raijinteks first all-in-one water cooler named Triton combines optimal processor cooling capability. The extraordinary performance is made possible by utilising a waterblock made of nickel-plated copper with micro channels, a 240mm Radiator with a high fin density along with a high-grade low-noise pump. The two 120 mm fans are manually adjustable and three coloured coolants are included for all tatstes and in the process illuminated by two integratyed LEDs.
- 240mm Aluminium Radiator
- Low-noise pump with graphite pipe
- Nickel-plated copper cold plate
- Resevoir with 2 Integrated LED's
- Red, Green, Blue or Transparent Coolant
- 2 x 120mm fans, Manually adjustable
- Easy & Secure installation
- Compatible to almost all sockets.
Specifications:-
- Fan Dimension 120 x 120 x 25 (mm)
- Fan Speed 1000 - 2600 RPM
- Fan Airflow 38.889 - 100.455 CFM
- Fan Air Pressure 0.744 -4.819mm H2O
- Fan Noise Level 21.6 - 41.6 dBA
- Fan Rated output 0.08 - 0.48 A
- Power Consumption 0.96 - 5.76 W
- Connector 3 pin
- Radiator Dimensions 275 x 120 x 32 (mm)
- Radiator Material 100% Aluminium
- Pump Dimensions 38 x 56 x39 (mm)
- Pump Bearing Type Graphite Pipe and Ceramix Axis
- Pump Q-Max 120L/Hr
- Pump noise 18 dBA
- Pump Life Expectancy 50,000 hours
- Pump Speed 3000 RPM @ 12v DC
- Pump Power 4 W
- Copper Cold Plate
Only £69.95 inc VAT.
ORDER NOW
They look really sweet, a lot like the ones ocuk used to make! Can you re-use the rad etc later? looks like normal compression fittings
hmm ive always been on air as aio ive seen have always been black tubed,but i think im gonna be purchasing one of there now as it can match my rig
How do these compare to other AIO's, heatsinks and custom water?
Also are you covered if it empties itself inside your PC?
where is the pump, i'm guessing it's in the water block, i am of course hoping that it's in the Rad or separate ;);)
if so all i need is the 7990 Water block.
Hang on- aluminium rad + nickel plated copper block? That's just inviting galvanic corrosion.
Curious as to wether the aluminium is anodized? There were similair concerns with the crosschill system on the mobo i use in sig. Quite an interesting peice of kit this cooler though. And well priced compared to an equivalent corsair AIO unit.
Between that 100% aluminum radiator and the 0.45 GPM max flow rate, I am quickly losing interest :(
Technically this isn't an AIO seeing how you will have to open it for the dyes and hence have to bleed air/add in more coolant as desired.
