Any news on the Classified edition?
Information on that model...
Is strictly...
Classified...
Okay.
It just looked a little strange because other models have all of the heat pipes across the chip, and I'm sure you have seen the same reviews as I have where they assume it is a design issue. You should get someone to put them right on that. Might deter customers.![]()
....this card looks suspicious to methe 2x 8mm ones do exaclty match the GPU. The third small one is to share the heat between the blocks. The 2 big pipes do cover the whole chip. We tried also a spreader above all three pipes but this did not work as efficient as the direct connection of the pipes.
Not sure what you mean with filled and capped?
Gibbo! For sli 970s are non-blower type coolers ok?
Is there going to be a 970 with a Titan cooler? Not digging the cheapo plastic ones tbh!
http://www.guru3d.com/news-story/evga-geforce-gtx-970-acx-has-misaligned-gpu-vs-heatpipes.html
If you look at the pic, the third small heat pipe has no "end" meaning it is just a metal tube with no contents, it isnt a functioning heat pipe
Would also love to know if EVGA think this is classed as a functioning heat pipe..
that pipe in the photo is just busted.......others wont be, the 3rd pipe not touching the cpu isn't a huge problem because the card still runs cold, this aint no 7990![]()
