Caporegime
- 13 May 2003
- Warwickshire
Hi all
I just want to run this thinking past you knowledgeables to check if it is sound or not.
We currently have a Ravenheat 120csi combi boiler in our house, which was there when we moved in. More than one outlet in use at any one time (e.g. someone uses a tap when the shower is running) causes poor performance from both outlets.
We've managed so far as there were only really two of us. However, our eldest is now three and we have a three month old, so our hot water demands are going to increase, with regular baths and showers becoming more of a feature.
House is a four bed with two bathrooms and a cloakroom.
Our choices seem to be: upgrade the combi to a beast with more power that can deliver a greater flow of hot water, or go unvented and swap the combi to a system boiler.
I'm fairly sure that the combi will be the cheaper option, but I love my super duper power showers, and both showers need to be usable with a strong flow at once.
Assuming that my flow and dynamic pressure is sufficient for both options, which would you go for? I have space for a cylinder if needed, but unless it'll blow the socks off a top combi, I'm not sure I want the added complication and expense.
Many thanks.
Many thanks.
