Hi there
Two cracking LG 29" deals making us the lowest price in the UK by far, check them out:-
LG Flatron 29UM65-P 29" WideScreen Super-Wide LED Monitor @ £239.99 inc VAT
The 29UM65 satisfies your demands for viewing pleasure and entertainment. Put high spec games on the 21:9 wide screen with astonishing picture quality of UltraWide Full HD (2560x1080) accompanied by 7W stereo speakers and satisfy your desire for the most realistic gaming experience and movie adventures.
With a 21:9 wide screen ratio, now you can multitask with 4 programs on one screen at the same time. This 4-Screen Split feature conveniently divides your screen from 2 to 4 customizable subscreens of your preferred size, without any overlapping of windows. Compatible with Mac®, it provides 8 different screen ratios, changeable by a single click, and increases not only your convenience but also productivity.
The Dual Link-up feature allows two devices to be displayed simultaneously on a single screen. With the monitor, you can connect and watch a movie from a Blu-ray player while working on an Excel spreadsheet from your PC. With the 29UM65's upgraded Dual Link-up, it enables HDMI+HDMI links, now you can connect devices more conveniently.
Reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for as long as you would like to. Enjoy your movies or games with realistic stereo sound. With the built in stereo speaker, there is no need for extra speakers around your monitor.
As LG IPS Monitor features consistency and less changes in colour temperature, it offers a colour impression identical to that of the original image. You can enjoy lifelike picture picture quality without any colour shift whether you are standing or lying down. It allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort.
Protect your eyes from exhausting flickers and blue lights. LG's new Flicker Safe system is always on to reduce the flicker level to almost-zero. In addition, activate the Reader Mode to minimize harmful blue lights with a simple touch of a hot-key. Spend as long as you want working, gaming, or watching movies without burdening your eyes. Use the convenient and easy hot keys for more satisfaction.
The joystick is a harmony of accurate menu controls and analogue sensitivity. With the fun control of a conventional joystick, its modern technology and design allow for simple control with a pleasant touch. In addition, intuitive UI with no overlapping is easier to understand and select menus.
Specification:-
- Screen size (inches): 29"
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 2560*1080
- Brightness (cd/m2): 300
- Contrast Ratio: 50000000:1
- Viewing Angle (°): 178/178
- Colour Depth (Num of Colours): 16.7M (8-Bit)
- Pixel Pitch (mm): 0.315 x 0.310
- Colour Gamut: sRGB
- Surface Treatment: Hard Coating (3H), Anti-Glare
- Connectivity: 1x DVI-D, 2x HDMI, 1x DisplayPort
- Warranty: 2yr
Was [£269.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
LG Flatron 29UB65-P 29" WideScreen Super-Wide LED Monitor @ £259.99 inc VAT
The 21:9 ratio is the perfect professional fit for software engineers, video / sound editors, and graphic designers. Imagine 2 conventional high quality monitors attached for multi-tasking, but their screens connect and extend seamlessly. Now you can use a program with long-range panoramic view in full length, without any bezel in the middle or dragging cursors. No longer divide your focus into separate monitors, the 29UB65 is the perfect companion for your profession.
Like other smart devices, the 29UB65's Pivot & Height Adjustable feature allows you to simply rotate the screen to fit vertically long images or files. When pivoting, you can easily adjust its height too. Leave dragging and scrolling behind. Let the monitor adjust to your images and needs.
Connect two devices to a single monitor with Dual Link-up that allows an HDMI + HDMI link. Now you and your colleague can simply bring each other's devices and connect to a single monitor to share and compare information. Freely show and control your screen while watching your partner doing the same on the opposite side of the monitor. Don't bother installing annoying projectors in your small room or worry when your conference room is occupied, the 29UB65 is here for you.
With its wide screen ratio, now you can open 4 programs on a single screen to see your information in a single glance while working. The size of sub screens is user-controlled. The 29UB65 is compatible with Mac® and not only provides convenience but also productivity in a single click, you can split your screen into 2 to 4 subscreens.
Specification:-
- Panel Type: IPS
- Contrast Ratio: 100000000:1
- Speakers: 2x 7W
- Warranty: 2yr
Was [£299.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
Specification:-
- Panel Type: IPS
- Warranty: 2yr
ORDER NOW
Specification:-
- Panel Type: IPS
- Speakers: 2x 7W
- Warranty: 2yr
ORDER NOW
