Perhaps there'll be a wonder driver that closes the tiny distance between Hawaii and Maxwell.
Don't think so, AMD will just have to release their yearly Mantle game to close the gap.
So the next iteration of AMD cards is not until 2015? In terms of tech, that is a long time away.
Nvidia certainly know how to work their customers into a frenzy, overcharge and under spec for a good few years, then become heroes when you offer the same performance at the same price of the competitions almost year old tech.
NVidia might initially overcharge but you'll never feel like they've simply took your money and run.
They offer a lot more post-sale than AMD though.
Shouldn't it be called the R9 295 then? 285X can't come in cheaper than R9 290 and beat it in performance, they would just be cannibalizing the 29X sales..
285X won't compete with the 970, AMD will release a 295 / 295X or 390 / 390X to compete with / beat Nvidia's new cards.
The 970 is an average of about 10% faster than the 290, thats the reference one with a 947Mhz clock.
The 285X would have to be 5% faster than the 290 to compete with the GTX 970.
The 285 is 0% to 20% faster than the 280 @ 1792SP, 918Mhz, 32 ROP's, 256Bit.
With 2048SP, 1050Mhz, 48 ROP's, 384Bit it should be at least 30% faster than the 280X, it could be as much as 50%.
It might just be possible.
You have some weird ass ideas about scaling.
500mm^2+ Fiji wouldn't be more than 5-10% faster than the 290X
but a Tonga with some extra bus width, few more ROPs and less than 15% more SPs is suddenly going to be 50% better than a 280X.
Full tonga even if it had a 384bit bus and 48 ROPs isn't even going to come close matching the 290 and 970. At best it would be a 960 competitor assuming the 960 gets 10SMMs. And while it would do that its power consumption would increase by quite a lot. That said I very much doubt tonga is a 384bit bus GPU because the PCB designs it has so far gotten have been for 256bit ones.
I did think this idea myself and made several posts about it, unfortunately for AMD when you see Maxwells TDP and efficiency for the number of transistors used it totally blows away anything the red team have got at the moment. A 290X packs 6.2 billion and a GK110 card 7 billion, a 980 outperforms both and only needs 5.2 billion transistors to do it. This is a killer before we get into heat or power consumption.
Until AMD come up with a completely new architecture it is a case of
Anything AMD can do Maxwell can do better.
Maxwell efficiency is the killer it is a bit like engine tuning, to increase horsepower you need to increase efficiency as well (unless you want to burn loads of fuel).
To put Maxwell in a little perspective. The 680/770 has 3.5B tansistors. The 980 is an evolution of that 'lite' architecture, +50% transistors for +40-50% performance. Some of those transistors (a good amount) will have been spent on finer power managment. However possibly fewer redundant structures/transistors required compared to the 770. Some perf gain coming from slightly higher clocks.
The GK110 packed 7B. It had 2x the transistors than the 680/770 for only +30% gaming performance. This is an awful and highly inferior architecture using some of the reasoning shown by ppl in this subforum. It is no surprise the 980 can outperform it using only 5.2B transistors. It should however give some indication of how much DP compute takes up. It also gives insight to the challenge facing nVidia with a full fat Maxwell core and why the lite maxwell 980 exists.
GCN maintains stong DP compute and will carry that transistor burden unless they decide to develop their own lite arch.
Can I ask a semi serious Question.
What is going to be the next big arguing point, memory bus width being the currant one?
Bear in mind that the 390X or the 490x will probably have this stacked memory tech and because of that only need a much smaller bus width.
30% is on the really high side. Memory bandwidth isn't going to increase the performance of the 285 that much. If the launch of the gtx 970/980 taught us anything, color compression can make up for a small bus size. And the r9 285 already has that going for it.
ROPs can help performance, but I think Shaders are overall far more important. ROP's become more important once you start increasing the power and amount of work the shaders can do.
This is why you will why ROPs are more important for Nvidia's architecture compared to AMD's architecture and why you won't see such a boost from AMD when they add 50% more shaders.
Clock for Clock, Nvidia maxwell cores perform about 30-40% better than their old keplar ones. Considering hawaii and the gtx 780 ti are pretty similar in core efficiency, I could see Nvidias core still being 30% higher than Tongas. Add in Nvidias ability to achieve about 30% higher clocks than a tonga card and this is why Nvidia's needs their ROPs. They simply have way more shader power at their disposal and adding ROPs to full tonga isn't going to have a big effect.
Considering there wasn't that many big changes between hawaii and Tonga this time around and Hawaii is certainly not ROP and bandwidth starved and the drop in the number of shaders for Tonga, I could see this r9 380x or full tonga performing about 80% of what a full hawaii chip is capable of.
Yeah, i had a pair of high clocking 670's and got roughly the same percormance from a single titan, i'm not sure where people are getting the +30% only from
