Is anyone using a Lamptron FC2 to control a DDC pump?
I´m asking because I tried to control my pump and if I leave on maximum 12V it works, but if I try to lower the voltage the pump stops instantly.
I got my voltmeter to test and I notice that the 12V doesn´t drop the voltage, instead the ground voltage raises when you lower the speed.
I know if you get 12V on positive and 3V on ground.. you would get 9V at the end, so why is the pump stopping?
