**TODAY ONLY! 30/09/2014** Corsair Flash Voyager Mini 64GB & Kingston HyperX Fury 240GB SSD
OcUK Staff
4 Feb 2013
Kingston HyperX Fury 240GB 2.5" SATA 6Gbps Solid State Drive (SHFS37A/240G) @ £109.99 inc VAT
High performance. Low price. You game?
HyperX® FURY solid-state drive delivers impressive performance at an affordable price, to get you into the game faster and improve your gameplay. It features a slim 7mm form factor and SandForce® SF-2281 controller with SATA Rev 3.0 (6Gb/s) performance for faster system boot up, application loading and file execution plus faster map and level load time. Its synchronous NAND allows for higher and consistent drive performance. So you're not only in the game, you're winning it.
HyperX FURY SSD is available as a stand-alone drive and is easy to install. This cost-e cient upgrade is less disruptive than buying a new system to increase performance. The new FURY entry-level product line from HyperX includes memory and SSDs and is designed for gamers, enthusiasts and system Integrators, who can now have consistent HyperX branding for their gaming PCs.
Built with Flash memory, HyperX FURY SSD has no moving parts and is cooler, quieter and more shock- and vibration-resistant than traditional hard drives, making it the ideal hard drive replacement. It’s backed by a three-year warranty and free technical support.
SandForce controller with SATA Rev 3.0 (6Gb/s) performance
Read/write speeds of 500/500 MB/s
Features synchronous NAND for consistent high SSD performance
Faster system boot up times, application loading & file execution
Faster map and level load times in game with increased frames per second
Baseline performance Compressible data transfer (ATTO) All capacities: 500MB/s read and 500MB/s write. Incompressible data transfer (AS-SSD and CrystalDiskMark)
240GB — 470MB/s read and 220MB/s write
Maximum 4k Read/Write
240GB — up to 84,500/ up to 41,000 IOPS
Random 4k Read/Write
240GB — up to 22,500/ up to 41,000 IOPS
PCMark® Vantage HDD Suite Score
240GB — 60,000
PCMark 8 storage bandwidth
240GB – 180 MB/s
Only £79.98 inc VAT.
ORDER NOW
_____
Corsair Flash Voyager MINI USB 3.0 64GB (CMFMINI3-64GB) @ £17.99 inc VAT
Flash Voyager Mini USB 3.0 is the tiny USB flash drive with full-size USB 3.0 performance. The USB 3.0 connector allows for optimal file transfer speed with the latest systems, and it’s fully compatible with USB 2.0. It comes with a detachable loop for attaching to your key ring, and the durable brushed metal housing resists wear and tear.
• USB 3.0 performance (compatible with USB 2.0)
• Compact aluminum housing
• Durable rubber strap and ring for convenient key-ring use
• Limited 5 year warranty
Only £17.99 inc VAT.
ORDER NOW
Nice price but it's very, very slow in comparison to others that are only a bit more expensive. Lots of reviews about so you can judge for yourself.
Am tempted to get one anyway! :D
Edit: I'd just like to add kudos to OCUK for printing the negative as well as positive reviews on their site. Lots of other sites don't - and I've checked with a few (and it's very annoying and frustrating)... so cheers for that! :)
You seem to get twice as much storage space with this one compared to the evo at the same/similar price
I might go for one, will be a nice upgrade for my first ssd...
You seem to get twice as much storage space with this one compared to the evo at the same/similar price.
Hey How you work that out ?
Kingston hyperx 240GB
Samsung evo 250GB
Almost exact same price
