Sony Z3 does look superb and is definitely on my maybe list. Still waiting for the N6 release though to see what it offers.
My N4 is now borked beyond belief. Stupid softkeys, stupid Xposed framework![]()
Yep thats what im doing aswell, but so far the "rumours" of the N6 are putting me off. (in terms of size)
I've been looking at either a G2 or G3. You can get a new G2 for £290 or a new G3 for £350 from Ebay.
About an inch too big... No thanks!
so you're fiddling around with the software using hacks and you blame said hacks for another issue? bravo
protip: stop xposed from being initiated during boot by hitting a software key repeatedly until it does a longish vibrate. voila, xposed not loaded.
Yes it's because I've had Xposed installed. It was working fine until this morning then the softkeys kept being very very slow to respond.
I checked the Gravitybox settings for navigation keys and that was all fine. Then I checked Android L Navigation settings and I think I changed from what it was on to another option. After the reboot no soft key has worked since.
I have installed new roms, flashed back to original stock, flashed back to PA and stuck a custom kernel on but the soft keys never work. Then put xposed and gravitybox and android l navigation back on and changed settings but the softkeys are still deaded.
If it's software though, how has it not reverted back after I changed it. Surely the settings would go back to default![]()
I'd play with a Z3 in a shop and then see what you think. You'll be back to purring as your stroke your N5 in no time.
have you tried flashing everything (i mean the partition tables) via fastboot and totally reverting back to stock? if that doesn't work, then indeed you've probably got a knackered phone.
What don't you like about it? I've only read good things.
