Mantle Comes To Sniper Elite 3!
What is the point of showing these benchmark comparisons with beastly CPUs? The area where mantle shows a massive improvement is when you have a high end GPU and a low/mid end CPU.....
I really should do a benchmark comparison at some point to show just much better BF 4 runs with mantle compared to DX on my rig, difference when in game is literally night and day, DX is just simply unplayable.
edit:
Just seen that matt has edited his OP.
I wouldn't call my old but still up for a fight i7 2600k weak. and I see improvement a lot.
I wonder how some of the 700 series cards would perform under the same conditions as on those charts if the drivers were not over 2 months old.
I thought the same thing, but atleast matt will actually play the game now as hes been waiting for it to get mantle support before playing it. Its a cracking game and I had absolutely no performance issues with it on max everything either on my hardware.
Oddly enough mantle results are a good bit lower than d3d in this.
5760x1080 d3d
Average FPS: 36.9
Minimum FPS: 5.4
Maximum FPS: 374.4
5760x1080 mantle
Average FPS: 15.9
Minimum FPS: 7.5
Maximum FPS: 25.1
Even at 1080p I only get around 53 fps, and for some reason mantle seems to disable supersampling even when its turned on in the options the benchark txt reports it as being off.
5760x1080 d3d
Average FPS: 36.9
Minimum FPS: 5.4
Maximum FPS: 374.4
5760x1080 mantle
Average FPS: 15.9
Minimum FPS: 7.5
Maximum FPS: 25.1
Could be the drivers, ive not updated to the latest ones yet.
Use 14.9 WHQL Gerard as this driver is recommended for Sniper Elite V3. :)
Performance is still pish in mantle with the benchmark thread settings, new driver got me the following at 1080:
Average FPS: 52.3
Minimum FPS: 17.6
Maximum FPS: 73.1
And as said according to the benchmark txt file it reports supersampling as being off when its turned on in game.
Average FPS: 52.3
Minimum FPS: 17.6
Maximum FPS: 73.1
Is it worth running the benchmark with supersampling off in-game/options and see if it changes the score?
See if it's just an error with the text files (results different) or if it's actually disabling supersampling (results are the same).
Average FPS: 52.3
Minimum FPS: 17.6
Maximum FPS: 73.1
Try enabling it in game and then quit. Check the benchmark thread for my results. I've noticed that it reports supersampling as off, but it's definitely enabled.
According to matt theres no crossfire support for mantle yet so its in single gpu mode currently which explains the fps, doesn't explain what's going on with supersampling though.
Does it make a difference to the Mantle results with supersampling set to off in-game?
No crossfire support for Mantle in games seems to be a reoccurring theme, which I find a bit disappointing really considering it's supposed to be such an absolute doddle to implement Mantle.
