No drivers for Windows 10?
3 Jun 2012
Hey
So I installed windows 10.
Seems AMD's 14.9's are not compatible as the Detection driver fails to load.
No sign of any mention of drivers from AMD.
Seems very odd that the driver doesn't work.
Anyone else tried it?
Asus Xonar's drivers don't install, it's obviously got an OS detection.
But Brainbit's work perfectly.
Haven't had a problem with default driver on Windows 10, bar maybe some performance anomalies. AC4 runs worse and notably.
I like a fresh OS install every now and again.
And tbh, Windows 10's perfectly stable, to be honest, it's just a tweaked Windows 8.
Yeah so I've read. Don't like the idea of Microsoft logging on if my PC reports issues. Also they have removed Media Center from the preview - not cool & potential deal breaker
Windows Media Centre was a paid component of Windows 8. I'd paid for it, so hope I can re-add it in or something.
And MS logging on to my PC? Sounds made up.
"Also, if your PC runs into problems, Microsoft will likely examine your system files. If the privacy of your system files is a concern, consider using a different PC. For more info, read our privacy statement."
Sorry mate
EDIT: On the MS website, under "before you install" section of preview
Windows 8 decided to become corrupt for me for hat ever reason. And I just didn't feel like using 8 again.
So decided to install 10 as my main OS. Seems fine so far.
And regarding MS snooping at system files... I couldn't care less at the moment. i use my pc so little that it wouldn't matter
