- 19 Oct 2008
"Also, if your PC runs into problems, Microsoft will likely examine your system files. If the privacy of your system files is a concern, consider using a different PC. For more info, read our privacy statement."
Sorry mate
EDIT: On the MS website, under "before you install" section of preview
It don't think it's anything new, it's the same as when Windows asks an error has occurred do you want to send a report to MS.It doesn't necessarily mean MS will access your system remotely - diagnostic tools will already be on the system. And if they did, they wouldn't access your PC without your permission.
System files does not equal personal files.
As we are getting an early look into Windows 10, I have no issue at all with helping MS. Software is so complex these days, especially operating systems supporting all sorts of hardware and types of users, the best way to test it is to get it out there for people to try and be able to gather as much information as possible about the problems that arise and uses of the software -ideally in an automated fashion.
