??? you don't get the point do you? it still wouldn't lower the temps to single GPU
I knew I shouldn't of posted, I really didn't want to get into this argument.
The point as you put it has nothing whatsoever to do with my post.
My post is just about the way you have put two completely contradictory statements in one post, on one line you say you will always get higher temps and then on the next line you say if you use V-sync you get lower temps. So ignoring everything else can you tell us all how you can always get higher temps ( the key word there is always), but if you use V-sync you get lower temps ( well that obviously isn't always then is it)
