Sniper Elite V3 Benchmark
22 Jul 2012
London
no, the card is clocked via Heaven only and then backed off for gaming, i never adjust it to suit any one game..........all games !!!!!
if i want more FPS then i'd buy another card next month :cool:
Huh? I think you misunderstand :)
As I'm sure you know, people often try and OC as much as they can for a benchmark. I was just remarking that this particular bench lets me get away with higher clocks than I'd normally manage in other benchmarks and was wondering if anyone else had found that to be the case for them too.
We all have everyday clocks for general use.
25 Jun 2009
aahh ..........well yes because SE 3 wont tax your rig much anyway, SE 3 is about the same as Serious Sam BFE :D
my GPU is backed off at least 50% for gaming, even so i'm not happy with 61fps so it looks like SLI .............. mind you, i never use 4X sampling anyway
22 Jul 2012
London
Yeah, it's not hugely demanding considering a single card can get decent enough frames at effectively 4k with 4xAA on top.
Still, I was seeing pretty much 100% usage across two cards at these settings fwiw.
Doubt you need SLI if you're happy with the one card in everything except this bench at these settings.
What are your clocks (inc boost) btw?
25 Jun 2009
well the real test will be Metro Last Light :eek: so i might take a look at that tomorrow and if it's much worst than 61 FPS then i'll deffo get SLI
Asus Strix = 1214 clock.............1866 mem.............1353 boost
so up approx 100 on each, but the Voltage cant be raised at all or it'll crash....it also has the fans at default and the power boost at default too, so as said, it's not exactly overclocked that far.
22 Jul 2012
London
Depends how much you like the look or notice the difference with SSAA really. Physx will give a bit of a hit too if you want that on.
With all that, you probably will want another card. If not, one'll do fine.
ED: Your card is voltage locked?
22 Jul 2012
London
Do we have a Metro LL benchmark thread?
I think so, now that you mention it... Pretty sure I posted in there actually.
Dunno if it really took off.
ED: By the power of search; http://forums.overclockers.co.uk/showthread.php?t=18512592&highlight=metro+light
Not exactly an organised bench thread though.
no you can adjust it but if you do it crashes instantly...well mine does anyway
One of the other 9** users can hopefully help you out there.
Then again, I was of the impression that they can go pretty high on just stock volts in most cases.
25 Jun 2009
yes it will go high if i put the full overclock on it, plus higher too if i upped the fans to 40%, plus 120% power boost..
as said, mine is backed off a long way, but i'll probably increase it soon anyway
Man of Honour
OP
21 May 2012
Dalek flagship
Remember if you post to list your clockspeeds for CPU and GPU also what drivers you are using.:)
25 Jun 2009
according to the other thread i'm screwed, the Asus only has an 8pin plug and a low power draw, it cant be over volted.
I tried overclocking really high last week but it suddenly hit a brick wall.....so then i upped the voltage and it crashed instantly, increasing the fan speed/power boost made no difference.
the limit is about + 300 on everything.............mine is +100 to keep it stable, it's only about 8 fps less so it's not a deal breaker, i just feel very cheated :mad:
30 Mar 2010
Under The Stairs!
Matts never going to let it slide:p so:
Single 290X @1200/1500
3770k @4.5
14.9 Drivers
Mantle
Sniper Elite 3 Benchmark Report (Mantle)
Created: 2014-10-07 at 14:49:20
Version 1.11a Build Version: 2014.10.03.001
Average FPS: 61.9
Minimum FPS: 19.8
Maximum FPS: 88.0
Number Of Frames: 4722
Average Frame: 16.145ms
Minimum Frame: 11.370ms
Maximum Frame: 50.544ms
Machine Name: TOMMY
Monitors: 1
Operating System: Windows 8 (build 9200), 64-bit
System RAM: 16329MB
CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Number of Cores: 8
GPU Name: AMD Radeon R9 200 Series
Feature Level: Mantle
Dedicated VRAM: 4096MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Obscurance Fields: ON
Tessellation: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
14 Jan 2005
Lincoln, UK
Mantle using Catalyst 14.9 whql, Windows 8.1
R9 290P (1180/1600)
4790k @4800
Average FPS: 64.1
Minimum FPS: 18.9
Maximum FPS: 86.3
Created: 2014-10-07 at 17:44:58
Average FPS: 64.1
Minimum FPS: 18.9
Maximum FPS: 86.3
Number Of Frames: 4884
Average Frame: 15.613ms
Minimum Frame: 11.585ms
Maximum Frame: 52.882ms
Machine Name: UNICRON
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 16295MB
CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Number of Cores: 8
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Man of Honour
OP
21 May 2012
Dalek flagship
R9 290P (1180/1600)
4790k @4800
Average FPS: 64.1
Minimum FPS: 18.9
Maximum FPS: 86.3
Average FPS: 64.1
Minimum FPS: 18.9
Maximum FPS: 86.3
Monitors: 1
System RAM: 16295MB
Number of Cores: 8
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
And on the scoreboard.:)
20 Nov 2005
Redditch
Updated score for me.
i7 4770K @ 4.5GHZ
R9 290 @ 1080/1450 14.9 drivers
Sniper Elite 3 Benchmark Report (DirectX)
Created: 2014-10-08 at 17:55:52
Version 1.11 Build Version: 2014.09.30.004
Average FPS: 56.5
Minimum FPS: 17.1
Maximum FPS: 195.5
Number Of Frames: 4311
Average Frame: 17.686ms
Minimum Frame: 5.115ms
Maximum Frame: 58.489ms
Machine Name: THEBEAST
Monitors: 1
System RAM: 16327MB
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Number of Cores: 8
Feature Level: DX11.0
Dedicated VRAM: 3072MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
18 Oct 2002
4 x 980 on Water at 1530/2000
CPU is 5GHZ 3930k on Water
Windows 8.1
DDR 2200 ish
344.16 WHQL
4k - 54.8 fps
Created: 2014-10-08 at 18:13:46
Average FPS: 54.8
Minimum FPS: 5.0
Maximum FPS: 508.0
Number Of Frames: 4167
Average Frame: 18.247ms
Minimum Frame: 1.969ms
Maximum Frame: 200.000ms
Machine Name: MAIN-PC
Monitors: 2
System RAM: 16322MB
CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Number of Cores: 12
GPU Name: NVIDIA GeForce GTX 980
Resolution Width: 3840
Resolution Height: 2160
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
