** New Expanded Edifier Range now in stock **
7 Feb 2011
Stoke on Toast
As mentioned in a previous post I have been working on increasing and expanding the Edifier range here at OcuK there are more units to come but I have had small quantities of the stock arrive.
Edifier Studio 980T @ £49.99 inc VAT
Compact in size, the studio 980T is an efficient 2.0 solution for desktops and small spaces. With 2 RCA ports and 24w RMS they will work with any laptop or computer.
- Dual RCA inputs for connectivity to multiple audio sources
- Calibrated flared bass reflex port, in front of the speaker cabinet
- 100% MDF wooden enclosure
- Universal switching power supply
- Active bookshelf speaker system with 24W total power output
Specifcations:-
- Total power output: RMS 12W × 2 (THD+N=10%)
- Signal to noise ratio: =85dBA
- Input Type: PC / AUX
- Audio input: Dual RCA input (RCA - RCA and RCA to AUX)
- Adjustment: Master volume control, bass adjustment control
- Frequency response: 70 HZ-20 KHZ +/-9db
- Input sensitivity: PC:700±50mV AUX:550±50mV (THD+N=1%)
- Subwoofer / bass unit: 4 inch (106mm), 6O
- Tweeter unit: 13mm silk domed tweeter, 4O
Dimension: 140(W) × 226(H)× 197(D)mm
Only £49.99 inc VAT.
ORDER NOW
Edifier R1600T III 2,0 60W Speakers @ £89.99 inc VAT
Edifier brings a revised version of their successful studio speaker. The Studio 1600TIII produces 60W RMS from the 4 inch bass driver and 19mm tweeter drivers in each speaker. A front facing bass reflex port emphasizes lower frequencies allowing for richer bass performance. The Studio 1600TIII incorporates DSP and DRC to prevent distortion levels even at the highest volumes, producing crisp, clean audio. Audio devices can be connected using the dual RCA inputs and audio volume treble and bass can be adjusted on the control panel on the side of the speaker. A wireless remove accompanies the R1600TIII for volume and power.
- Active bookshelf speaker system with 60W total power output
- Bass, treble and master volume controls located on the side panel
- Professional amplifier system with Digital Signal Processing and Dynamic Range Control
- Class D amplifier with 4inch bass drivers and ?19mm silk dome tweeters
- Wireless remote control with mute and volume adjustment
- 100% MDF wooden enclosure to minimize acoustic resonance
Specifications:-
- Total power output: RMS 13W x 2 + 17W x 2
- THD + N (testing level):10%
- Distortion: =0.1%
- Input sensitivity: PC: 700mV±50mVAux: 550mV±50mV
- Input impedance: 10KO
- Audio Input Type: Stereo RCA line-in ports
- Adjustment: Wireless remote control for volume and powerMaster Control for Volume, bass and treble adjustment
- Frequency Response: R/L: 3.3KHz - 20KHz | SW:30Hz-3KHz
- Subwoofer / bass unit: 4 inch (119mm), 6O
- Tweeter unit: 19mm, Silk dome tweeter, 6O
- Control panel:Volume, bass, treble, power indicator
- Dimension: 154 mm x 254mm x 214mm (W x H x D)
- Weight: 6.4Kg net | 7.4Kg gross
Only £89.99 inc VAT.
ORDER NOW
Edifier M1550 Multimedia 5.1 Speakers @ £49.99 inc VAT
The M1550, a 5.1 speaker system by Edifier is an efficient mini home theatre solution, or simply a speaker system for optimal surround sound. The wooden encased subwoofer provides rich sound while the volume is controlled with ease via the wired remote controller. Triple 3.5mm jacks allow the ability for both stereo input signal and 5.1 channel input signal.
Main Features:
- Subwoofer / bass unit: 4 inch (106mm), Magnetically Shielded, 6 ohms
- Midrange / high unit: 2 inch x 3½ inch (50mm x 90mm), Magnetically Shielded, 4 ohms
- Mini home theatre/surround sound 5.1 multimedia speaker system
- Wooden MDF subwoofer enclosure
- Master volume control, green indicator, stand-by option, and line-out for headphone all included on wired remote controller
- Triple 3.5mm jacks accept both stereo input signal and 5.1 channel input signal
Specifications:-
Total power output: RMS 4 x 3W + 4W + 10W x 1
THD + N (testing level): 10%
Input sensitivity: Satellites: 350mV ± 50mV | Subwoofer: 80mV ± 20mV
Audio Input Type: 3.5mm Line in, Headphone jack
Adjustment: Wired remote control, volume control, mute/play button, bass control on subwoofer
Subwoofer / bass unit: 4 inch (106mm), Magnetically Shielded, 6O
Midrange / high unit: 2 inch x 3½ inch (50mm × 90mm), Magnetically Shielded, 4O
Remote control: Wired: Volume adjustment, mute/play button, Headphone jack, LED indicator light
Dimensions: Subwoofer: 158mm x 226mm x 223mm | Satellite front/surround: 68mm x 166mm x 86mm Center satellite: 160mm x 66mm x 60mm (WxHxD)
Weight: 4.50Kg (net)
ORDER NOW
Edifier M1380 Multimedia 2.1 Speakers @ £39.95 inc VAT
For excellent PC sound quality, look no further than the impressive Edifer M1380 2.1 PC Speakers.
This 2.1 speaker system can help you to get the very best sound from your PC. Comprising of two 8W satellite speakers that are matched with the subwoofer for great sound quality, you can expect clear and rich tones from the M1380.
The 12W subwoofer is encased in MDF with a front bass reflex port that helps to deliver great audio.
There's plenty of things you can connect the M1380 speakers to thanks to the 3.5 mm connection and RCA input, giving you ample choice. Whether you blast out some tunes from your mp3 player or immerse yourself in your favourite game, you'll be sure of the very best sound.
Specifications:-
- Total power output: RMS 8W x 2 + 12W x 1
- THD + N (testing level): 10%
- Input sensitivity: Satellites: 450mV ± 50mV | Subwoofer: 70mV ± 20mV
- Audio Input Type: 3.5mm Stereo line-in, Auxiliary input, Headphone jack
- Adjustment: Power, Base, Volume, Mute
- Frequency Response: Satellites: 140Hz - 20kHz | Subwoofer: 20Hz - 130Hz
- Subwoofer / bass unit: 5 inch (131mm), Magnetically shielded, 4O
- Tweeter unit: 2¾ inch (70mm), Magnetically shielded, 4O
- Remote control: Wired: Volume control, headphone jack, mute
- Control panel: Bass trimmer, Power switch
- Dimension: Satellites: 120mm × 151mm × 125mm | Subwoofer: 164mm × 220mm × 280mm (WxHxD)
- Weight 4.20Kg (net) / ˜5.20Kg (gross)
Only £39.95 inc VAT.
ORDER NOW
How do they compare to the R1600T II?
Thinking of going for the 5.1 setup to make use of my soundcard
The 5.1 will not be as good as the 1600T but then it's hard to compare 5.1 multimedia set up with a 2.0 set up.
should be absolutely fine I just can't really say if it will be better given the differences in both.
Yeah ..I have a set of the other 1600s the 1600T Plus ,and for music and films they are very nice...but I don't like them for games ...so at the moment im using a Logitech 5.1 set up....although I think they are not gonna last much longer
The flat response can be a bit lifeless in games - looks like the IIIs might be a bit more adjustable potentially with better ability to configure them for gaming though personally I prefer headphones for gaming.
Agreed, For movies and music 2.0 or the 5.1 but for gaming, using good quality Headphones (ATH for example) makes a difference when you can pinpoint where the enemies are sneaking from...campers
What are the chances for using the 980T with own amp ? will that work ?
no it's the output from one to the other if you bought 2 sets you could use the left ones passive.
I'm pretty sure you could convert them to passive easy enough but they can't just be used passive.
I have had a look but I cant see that OcUK sell a cable to hook these up to a onboard/soundcard via 3.5mm.
Some sort of 3.5mm to twin RCA cable I think?
Pretty standard cable/adapter, cheap also.
Are they gong to update their high end 5.1's?
cable comes with the speakers Speaker cable is not an area we can compete with the rainforest and richersounds on so we avoid it.
