Hi!
My 7850 is starting to struggle in some games @1080p but I decided not to buy the GTX 970 now as I'm a little short on lolly. I figured it'd be better to see what AMD has in store for early 2015. However, I found a bloke who has 10 280x cards for a little less apiece than a half of what a new GTX 970 goes for (and I can easily sell my 7850 to make the upgrade even more affordable). All the cards are practically new (just unpacked) and come with 2-year warranty (which is fine since I don't even plan to keep the card for that long), the box and all the accessories are also included.
Do you think it's worth buying the 280x as a stop gap before proper 20nm GPUs? I reckon I could use it for quite some time before it really starts to struggle in games (and no, I don't necessarily have to run everything @60fps locked;p)...
The only problem I can think of is my PSU. It's a 500W OCZ SXSII and I'm not sure wheter it'll be up to the task. I have a 4790k running at stock clocks, 1TB HDD and a 256gb SSD. I know I should get rid of this PSU and replace it with something beefier, which I will eventually do (just can't afford it ATM).
