- 21 Jul 2005
- Officially least sunny location -Ronskistats
I think AMD CPUs are having great prices for their performance at the moment. But they have many drawback such as limited choice of motherboard, quite hot, consumer decent level of power and based on a very old architecture. But performance wise, they are great.
I am probably sounding subjective, but owning an 8320 based system I can only raise a brow on the past couple of posts!
Bear with me here. I think they have quite a plethora of motherboards offering good features and scope for overclocking. Yes they run hot when benching (does anyone do this though for long periods instead of other things?) but compared to the machine it replaced (C2D) I measured at the wall and it is more efficient than that.
From the other post (Bonjour), they are actually great for gaming and I would quite comfortably say that the majority of 'gamers' still use 1080p with low to mid range components. You really are catering to the select audience on these forums that demand the high power rigs, probably less than 5% of the market at a guess.
I will concede that it is becoming older tech, and the refreshes AMD keep spawning are not helping the avid enthusiast. To call them not great though is bordering the brainwashed retort from reading too many myths on this area of the forum.
Enjoy the performance they give at least for the short term, as in a couple of years they can be replaced by something more substantial - if you need it. In the mean time they will do absolutely fine, from my opinion only a far more expensive i7 would be the upgrade worth considering.
