Need some advice on DNS setup (123 Reg domain & GoDaddy hosting)
13 Jan 2004
South East
Hi all,
I have an IP address that I need to point my domain name servers to.
GoDaddy say that I need to add an A record for this.
Now, do I add an A record for www only, to go to this IP address?
Or should I also be adding something else as well? Like a CNAME? How do I make sure if someone puts in www.mydomain.com and mydomain.com, it goes to the same place?
I'm not that great at this stuff, I just need to know how to point my domain at my hosting in the best way.
Thanks
EDIT: Would a * A record be a good idea to cover it all? Should I have that as well as a www A record, or instead of? Does this cause any SEO issues?
Well, it is working but I'm worried that I haven't done what was suggested and that it may cause problems in the long run.
At the moment it is working if I put domain.com or www.domain.com into my broswer, this is what I have:
www A 111.111.11.111
* A 111.111.11.111
Not the real IP by the way.
How do I create a non-www A record? Is that the *?
Once I've done this, shall I change the www one to a CNAME?
Thanks
EDIT: I've cancelled with GoDaddy, it was slow as ****. Going to add the site to my current hosting package with South West Broadband, they should be able to help me out with the DNS stuff too :)
I'd point the non-www at the A record, then CNAME the www one. You might not be able to use wildcards
Yup; typically (obviously it doesn't apply to every situation) you'd use CNAME's for subdomains and A records for domains - 'WWW' is a subdomain :)
* A 111.111.11.111
Usually the star would indicate a wildcard, so everything pre-domain.com uses the A record to point to 111.111.11.111.
In this case, the separate 'www' record would be redundant as it would already be covered under the wildcard.
Obviously using wildcards is fine unless you're planning to have multiple A records for a single domain.
As for "How do I create a non-www A record?", you'd generally just enter in the domain on it's own, so it'd look like -
Code:
mydomain.com		A		111.111.111.111
www.mydomain.com	CNAME		mydomain.com
