Some of you might have seen me post about my mum buying the above car, well I got it instead, to replace my 130i M Sport, yea, bit of a change. But I'm absolutely in love with it. It's incredibly practical, perfect for trips down the yard and pulling boxes. Comfy on normal runs and great on the motorways. Not fast by any stretch, but fine for today's roads.
Anyway, a 13 year old vehicle costing £1,800 isn't without it's faults. So here they are:
The ones I need help with are the heating ones, and the whine. I've not done any investigation what so ever bar checking the turbo in case it was related to the whine (it's not). Is it worth dumping the car in a garage or are most of these simple things, simple enough to the point a home mechanic can sort them? I've ordered shocks already.
- Driver side shock failing, 1" lower than passenger side
- The AC doesn't work
- Heating only blasts out lava at any settings, even when turned to 0 and cold, hot air still comes out
- Drivers window doesn't go down, jams about 2" down. The window can be moved and shimmied to go lower, I'm thinking it's loose in the door
- Electric mirrors don't work
- Some form of whine that occurs between 2k and 4k revs. Not sure what this is, turbo's fine, as are all belts...
