- 22 Feb 2014
I am hoping you can help with our bedroom ligting problem.
Currently we have 1 single pendant light in the centre of the room and I find that it doesn't throw enough light at the ends of the room.
The simple solution would be to replace the fitting with one of those spotlights on a rail/track.
I can't help but feel that spotlights aren't appropriate for a bedroom though.
So apart from moving the existing fitting to one end of the room and installing a 2nd fitting at the other end, is there any type of "bedroom suitable" light out there that I could replace the standard pendant type with ?
