Hi there
Unlike our competitors we have some really low priced DDR4 in stock too as well:-
Crucial 16GB (4x4GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K4G4DFS8213) @ £149.99 inc VAT
In the ever-changing world of technology, any component more than half a decade old is usually in need of an update. At seven years old and counting, that’s exactly the state DDR3 memory is in: computers can only do so much with it.
Since the introduction of DDR3 memory technology in 2007, processors have doubled in capability, SSDs have revolutionized throughput, and graphics cards have drastically increased frame rates, leaving memory as a limiting factor. With Crucial DDR4 Desktop Memory, crush the DDR3 memory bottleneck and unlock a new standard of performance.
Load applications faster and run demanding programs without lag. Crucial DDR4 memory debuts at 2133 MT/s – more than 30% faster than DDR3 memory technology.1 Even better, as DDR4 technology matures, speeds are projected to hit 3200 MT/s – twice what was possible on standard DDR3 memory.
Effortlessly multitask between apps, and empower your system to fire on all cylinders. Crucial DDR4 increases memory bandwidth by over 30%, allowing your system to handle more data at once. As DDR4 technology matures, bandwidths are expected to achieve up to 25.6 GB/s – twice that of standard DDR3. To maximize bandwidth, Crucial DDR4 memory is optimized for nextgen platforms that support four channel memory.
Get better performance – using less power. Operating at just 1.2V compared to 1.5V for standard DDR3 memory, Crucial DDR4 consumes 20% less voltage than standard DDR3 technology. Crucial DDR4 modules also contain other efficiency features, for an overall power reduction of up to 40%.
As a brand of Micron, one of the largest memory manufacturers in the world, Crucial DDR4 memory represents the future of computer performance. From the original DDR technology to DDR4, we’ve engineered the memory technologies that have powered the world’s computers for 35 years and
counting. When you choose Crucial DDR4 memory, you’re choosing memory that’s backed by a limited lifetime warranty2 and designed for the world’s leading systems. Don’t settle for anything less.
Specification:-
- 2133MHz (PC4-17000)
- CAS Timings: 16-16-16
- Voltage: 1.20v
- Warranty: Lifetime
Only £149.99 inc VAT.
ORDER NOW
Crucial 32GB (4x8GB) DDR4 PC4-17000C16 2133MHz Quad Channel Kit (CT4K8G4DFD8213) @ £299.99 inc VAT
Specification:-
- Voltage: 1.20v
Only £299.99 inc VAT.
ORDER NOW
TeamGroup Elite 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (TPKD416GM2400HC16QC01) @ £179.99 inc VAT
TeamGroup Elite DDR4 offers great value and great performance with superb looks with all black PCB and heatspreader design,.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 16-16-16-36
- Tested Voltage: 1.2V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
Only £179.99 inc VAT.
ORDER NOW
We are miles ahead of competitors when it comes to DDR4 range and selection in stock.
