**NEW CASES from Phanteks **
7 Feb 2011
Stoke on Toast
Due in 2 weeks Germany already has stock
Phanteks Enthoo Primo Full Tower - Black/Gold @ £199.99 inc VAT
The bar has been set to a new standard with Phanteks’ release of their first Enthoo series case. Passionate about cooling and the one that brought you the world’s best air coolers, Phanteks enters the case arena with their functional design with exceptional cooling possibilities, the Enthoo Primo.
Accessibility and functionality is what sets the Enthoo Primo on a level of its own. It was constructed from a builder’s point of view with the closest attention to detail. This Enthoo Primo combines innovative design and rich styling that appeal to builders of any caliber. A glimpse through the split window side panel reveals the clean interior, capable of being water cooled, air cooled, or both.
Phanteks’ Enthoo Primo, unleash unlimited possibilities.
Specification
Case
- Colour: Black / Blue LED
- Form Factor: Full tower
- 5 Phanteks’ PH-F140SP premium 140 mm fans included
- Material(s): Aluminum faceplates, Steel chassis
- Motherboard support: ATX, EATX, mATX, SSI EEB
- Front I/O: 2x USB 3.0, 2x USB 2.0, Mic, Headphone, LED switch
- Side window: Yes, split-window design
- Expansion slots: 8
- Power Supply Slots: 2
- Dimension: 250(W) x 650(H) x 600(D) mm
- Warranty: 5 years
Drive Bays
- External 5.25” 5
- Internal 3.5” 6 (2x 3HDD cages)
- Internal 2.5” 12 (2x 3HDD cages + 2x doublestack SSD brackets *expandable to 3x)
Cooling (120mm fans)
- Front: 2x
- Top: 4x
- Side: 2x
- Rear: 2x
- Bottom: 4x
- HDD: 2x
- The PWM hub will enable PWM function to 3-pin fans. Total of 11 fans can be connected to the PWM hub.
Extensive water cooling support provides 5 different installation areas for slim and thick radiators varying from single to quad (120mm and 140mm form factors) with clearance for push-pull fan configurations.
Liquid Cooling Features
- Reservoir Brackets
- Pump Bracket
Radiator Support
- Front: Up to 240mm
- Top: Up to 480mm or 420mm
- Side without HDD Cages: Up to 240mm
- Rear: 120mm or 140mm
- Bottom: Up to 480mm or 280mm
Clearance
- CPU cooler 207mm
- Cable management 30mm
Only £199.99 inc VAT.
ORDER NOW
Phanteks Enthoo Primo Full Tower - Black/Orange @ £199.99 inc VAT
ORDER NOW
God damn it, thought this was the Enthoo Primo mini then!
Built my hopes up!!
I was expecting that too mate. The colours look a bit crap to be honest, they should stick to what they've been doing, these look a bit to far out of the box compared to what they have been doing.
I got all excited when i saw this, however i dont like the look of the gold one, but the orange isnt too bad. Would love to see a red and black, or green and black.
It is nice to see that they are not trying to charge a ridiculous premium for them.
For those wondering about the price, watch this brilliant review of the case:
And then compare to other cases that are more expensive. It was arguably the best case of 2013.
This is 2014 an there still on 2013 prices, lovely cases worth the price tag? no chance
the price of a case doesn't generally change over the course of a year.
The only time a case tends to drop in price is if it is replaced by the same manufacturer.
the fact is, its been out a year and not much has come out that has bested it.
If you want to show me something that has more features for £200, please do.
I buy cases for a living and would love to hear more about products like that.
Well if you can show me some thing that the case can do that others can not, il show you a case that can do the same for cheaper.
When it comes to cases its all down to taste an preference to the customers needs an cosmetic look not just what the item can actually do
What other case for the same or less money offers space for at least 480+480 thick rads for starters? I'd honestly love to know.
You can find the rest of the features in the posted vid above.
