i had 1 in a pre facelift celica, the preface only suffer a design fault with the oil rings on the pistons causing it to use oil and blow the bottom end.
pre face is 99 - 52 face lift is 52 to 55 they are not bad motors and are a bit more economical but not worth sacrificing 50 bhp worth. still good fun and cheap.
you can get 200k out of these engines with not much more then oil changes
