Poll: Which GTX970 do you have that has coil whine?
  • MSI Gaming - with coil whine
    Votes: 24 19.2%
  • MSI Gaming - without coil whine
    Votes: 41 32.8%
  • Gigabyte G1 - with coil whine
    Votes: 8 6.4%
  • Gigabyte G1 - without coil whine
    Votes: 11 8.8%
  • EVGA ACX - with coil whine
    Votes: 3 2.4%
  • EVGA ACX - without coil whine
    Votes: 0 0.0%
  • Zotac Gaming - with coil whine
    Votes: 1 0.8%
  • Zotac Gaming - without coil whine
    Votes: 2 1.6%
  • Inno 3D - with coil whine
    Votes: 1 0.8%
  • Inno 3D - without coil whine
    Votes: 7 5.6%
  • Palit Jetstream - with coil whine
    Votes: 0 0.0%
  • Palit Jetstream - without coil whine
    Votes: 2 1.6%
  • Reference cooler/board - with coil whine
    Votes: 1 0.8%
  • Reference cooler/board - without coil whine
    Votes: 5 4.0%
  • Galax - with coil whine
    Votes: 8 6.4%
  • Galax - without coil whine
    Votes: 11 8.8%
  • Total voters
    125
Don
17 May 2004
Telford, Shropshire
As title, also for discussion about coil whine.
clean slate on this one guys - I broke the last thread, sorry! I'll see about if it's possible to recover.
i have had my MSI 970 longer than 14 days, then its the whole rigmarole of getting the RMA raised, then i am sure OCUK will have to send this off to MSI (dont think OCUK would deal with the RMA on this?)
it works, and can only hear it if i am like half a metre away
sat about 1.5m away as i am, can hardly hear it... but its that little nagging thing in my head knows it is there.
also, that 'Buzzing' is that classed as coil whine or is it something else
Gibbo posted this last night:
As an official statement to stop people quoting bits here and there this is our official policy on coil whine below:-
OcUK will accept an RMA for a card which has coil whine in extreme circumstances which we consider to be audible on a quality single rail PSU of gold rating or higher. Audible as in coil whine in normal usage and gaming which is audible above case fans in a closed case. Coil whine in benchmarks is not considered as a fault. It's not actually a fault in the hardware as such if a card whines, it is inherent in graphics card design, but we will class it as a fault for cards which are clearly audible in normal usage (gaming). For example two identical cars, one will consume upto 1l of oil every 1000 miles and the other one consume nothing, this is not considered a fault by the manufacturer and it is operating within specification.
From this thread here
Serious question which I raised in the other thread;
Why don't NVIDIA use a small amount of glue or something similar on the components on the PCB which are susceptible to resonate and cause coil whine? As far as I know it is something that most PSU manufacturers do, and people have succeeded in stopping coil whine by doing something similar to a GPU themselves.
If that isn't really viable, I'm sure they could amend how the components are affixed to the PCB or something, for a similar outcome?
Does coil whine get worse/better or stay the same with time?
It might lessen in time, sometimes noticeably, sometimes not. But if it is there, it is unlikely to go away completely. I stressed my 780 for a week solid to try and reduce the coil whine, but it was still squealing like an agitated cat at the end of it. :(
Powercolor did this with their 290 card and it seems to have solved the issue. I agree though that it should be done, it's a no brainer really. It's really up to the board manufacturers I guess.
Typical AMD fanboi :rolleyes:
jk
JK
I would agree with the above though. How much does a few blobs of glue cost?
Needs a strix option, but tbh i dont know if i'd shoose with or without as it is silent when idle and I didnt hear any when trying 3dmark, just a faint amount as windows was loading after some windows updates. Dont hear any now as windows loads so fast anyway.
PSU= Seasonic X-series 660w
Probably worth bringing up: As people with problems are more likely to come to a thread about problems we won't, from this, get a good idea of what proportion of a given card do whine. However, as this applies equally to all brands, we may be able to compare the vote proportions by brand to get a hint if some cards are better or worse.
Maybe because they only make reference boards which are mostly fine and free from coil wine.
When it comes to the cards with a custom PCB that is on the vendors and not Nvidia.
tbh, the majority of people who click on this thread are probably those suffering from coil whine.
those that aren't are probably too busy enjoying their gaming to visit here ^_^
Still a good indicator as to what card does have coil whine though,
I know the msi as sold a load on here, so percentage wise i would think it will be higher.. But if no one votes on a certain card then that should prove that the card is pretty much coil whine free
